Add FedEx shipping quotes
Thread begun 10/22/2009 1:02 pm by eric284736 | Last modified 10/27/2009 2:23 pm by Jason Byrnes | 5067 views | 9 replies |
eric284736
Do I add this to the checkout page? Then the quote would show up on the confirm page?
thanks,
Eric
No, you add the FedEx Rate lookup behavior to the Confirm page.
eric284736
thanks Jason, I will give that a try :)
You're welcome.
eric284736
Jason,
How do I get the rate to show up on the confirm page? I ran thru the FedEx shipping behavior, but the charge is not showing up under shipping.
thx
Eric
Is there a fedEx rule added on the shipping tab of the eCart object?
In the eCart object, go to the shipping tab. there should be a fed ex rule.
if not, click the plus button to create the new rule.
Set the trigger to Based on fed Ex Shipping Quote value.
set the calculation to Based on fed Ex Shipping Quote value.
eric284736
Yes, the rule appears correctly. The trigger should be set for "before the page loads?"
thx
Eric
The trigger should be Based on fed Ex Shipping Quote value != 0
eric284736
Here is the page (some info is modified for security).
Something is not correct :)
thx
Eric
The fed code is at lines 357 - 452, the to address use information from the session collection.
the session variables are created after the fed code at lines 453 - 639.
to use the session information, the fed ex code must come after the session code.
