Error on page load
Thread begun 10/22/2009 4:28 am by mail361522 | Last modified 10/22/2009 3:53 pm by Jason Byrnes | 7348 views | 19 replies |
mail361522
Error on page load
Hi. I just purchased and installed HTMLEditor v 2.0.0. Seems fine. But when I installed it and tried it on one page, the page shows an error (when web browser loading it):
"Toolbar 'Custom' does not exist!"
I checked that the custom subdirectory (and all other files) exist at the web server and confirmed that the links seem correct. This is my code:
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("text", "../HTMLEditor/", "400px", "200px", "Custom", "../custom/admin_Insert_text1.js", "");
Please need help!!! Regards!
neilo
That code looks correct, assuming your page containing the form resides inside a folder in your main site - i.e. not in the root directory, and all the files have been uploaded. Does it test OK in your local site?
mail361522
Yes. I'm running the site locally as well (with IIS) everything works except HTML editor, so it should not be server related. I have retried creating a blank new site with just a simple form and still get this error.
mail361522
This is my simple test page, very basic:
[code]
<?php require_once("HTMLEditor/WARichEditorPHP.php"); ?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
</head>
<body>
<form action="testagain.php" method="post" enctype="multipart/form-data" id="form1">
<p>
$WARichTextEditor_1 = CreateRichTextEditor ("text", "HTMLEditor/", "400px", "200px", "Custom", "../custom/test_text1.js", "");
</p>
<p>
<input type="submit" name="submit" id="submit" value="Submit" />
</p>
</form>
</body>
</html>
[code]
Besides this file the only thing in the directory is the HTMLEditor folder unchanged. Error message is "Toolbar 'Custom' does not exist... Bad!!! Please Help Webassist!
in the address bar, replace "filename.php" with "HTMLEditor/custom/test_text1.js"
in other words if you browse the page with the HTMLEditor instance to it at:
file.php
change it to:
test_text1.js
This should open the test_text1.js file in the browser.
If not, please check your site settings.
On the Local info tab, Is the Local Root Folder the same as the Testing Server Folder on the Testing Server Tab?
If they are different, In the Dreamweaver Files Window, select the HTMLEditor folder and click the blue up arrow to upload it to the testing server folder.
mail361522
Yes, the custom *.js link opens up in the browser.
Yes, all site folders are the same, I did a very basic setup to make it easy to check!
Please send a copy of the HTMLEditor/custom/test_text1.js file so I can examine it.
mail361522
// Custom configuration for iRite
FCKConfig.XMLFullName = 'grundlaggande';
FCKConfig.XMLFileName = 'grundlaggande.xml';
FCKConfig.SkinPath = 'skins/silver/'; // relative to fckeditor/editor/fckeditor.html
FCKConfig.DocType = '<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">';
FCKConfig.AutoDetectLanguage = true;
FCKConfig.DefaultLanguage = 'default';
FCKConfig.StartupFocus = false;
FCKConfig.FullPage = false;
FCKConfig.BaseHref = '';
FCKConfig.DefaultLinkTarget = '_blank';
FCKConfig.ToolbarSets["Default"] = [
]; /* Toolbar end */
FCKConfig.ForceStrongEm = false;
FCKConfig.FormatIndentator = ' ';
FCKConfig.EnterMode = 'p';
FCKConfig.FillEmptyBlocks = true;
FCKConfig.FormatOutput = true;
FCKConfig.FormatSource = true;
FCKConfig.IncludeGreekEntities = false;
FCKConfig.IncludeLatinEntities = false;
FCKConfig.ProcessHTMLEntities = false;
FCKConfig.ProcessNumericEntities = false;
FCKConfig.AdditionalNumericEntities = '';
FCKConfig.ForcePasteAsPlainText = true;
FCKConfig.CleanWordKeepsStructure = false;
FCKConfig.EditorAreaCSS = ''; // relative to fckeditor/editor/fckeditor.html
FCKConfig.BodyClass = '';
FCKConfig.StylesXmlPath = ''; // relative to fckeditor/editor/fckeditor.html
FCKConfig.ManagerEnabled = false;
if (false) {FCKConfig.Plugins.Add('kfm');}
here's the problem:
this should be something more like:
FCKConfig.ToolbarSets["Custom"] = [
['FitWindow'],
['TextColor','BGColor'],
['Anchor'],
['Bold','Italic','-','OrderedList','UnorderedList','-','Link','Unlink','-','About']
try editing the HTMLEditor instance. Click the Customize button next to Editor Preset, go to the toolbar button and add the toolbars you wish to use.
mail361522
But what I did was creating a new preset with the "preset manager" prior to adding the html-editor instance to the textarea. I have done NOTHING else. For me the reason to upgrade iRite was the ability to make easy presets as I usually have a lot of changes and a lot of editor instances. I don't want to make manual changes to scripts, otherwise I could just download FCKeditor for free and use it...
