nothing to choos
Thread begun 10/22/2009 4:24 am by PeterL | Last modified 10/23/2009 2:50 pm by Jason Byrnes | 2631 views | 4 replies |
PeterL
nothing to choos
purchased Sculptor 3 today.
Fixed already the .js problem but now there is nothing to choose in the menu
(see attachement 1) I also discovered that in my en_US folder there are 2 maps?
Is that a problem?
See also attachement 2
Peter
What is the full path to the configuration folder?
Can you select the configuration folder and use Option + I to get info and post a screen shot of the Info window?
Having 2 configuration folders is not a problem. Dreamweaver will only use the one named Configuration the other will be ignored.
PeterL
The full path to the configuration folder:
user/library/Application Support/Adobe/Dreamweaver CS4/en_us/Configuration
(see attachement)
PeterL
Problem solved
Hello Jason,
I could solve the problem by uninstall Dreamweaver and removing the Aplication Support files. After that re-install and everything is oké now.
Thanks for your support anyway
Peter
Excellent, glad to hear it is working.
