Insert / update record strips characters
Thread begun 10/22/2009 2:35 am by pascal267973 | Last modified 10/22/2009 12:33 pm by Eric Mittman | 1459 views | 1 replies |
pascal267973
When I use the insert / update record function, if a '|' is entered as part of a form value, the '|' and everything after it gets deleted and is not inserted in the database. This only happens when this particular character is present and doesn't happen if I use the insert or update Dreamweaver behaviour.
Do you know what could cause this problem?
Thanks.
Pascal
I think that this has to do with how the insert and update server behaviors evaluate the values, there is a string that is created of the values that uses this character as the separator. Then these values are transformed into an array like this:
$WA_fieldValues = explode("|", $WA_fieldValuesStr);
Since it is just looking for this vertical bar character it will find the one you add and break the other values.
You should try either replacing the character with the encoded value for it '%7C' or you can try wrapping the php function that does this for you around the value in the insert server behavior like this:
htmlentities(<the value>)
