Attachment Woes With FB File Form Element in UE
Thread begun 10/21/2009 7:31 pm by paputxi | Last modified 10/28/2009 12:53 pm by Jason Byrnes | 6438 views | 14 replies |
paputxi
I recently worked through a problem I was having with attaching files to an email where I had created a File Field form element directly into the form using Dreamweaver rather than via Form Builder. (Thanks, Jason, for that.) However, I now seem to have a problem with receiving an attached file where I used Form Builder to create the file form element.
To simplify the problem I am having, enclosed are files associated with a very simple form of just two fields, one a text field and the other the file to be uploaded. I followed the same steps I had used earlier (i.e., from "How To Include Attachments with your Email form" and I did create a folder named "attachments" at the same level at the test1.php file on my website and I did make sure that I had set the attachments folder online to have read-write permission (a big problem I had earlier and from what others have experienced from reading similar emails. That probably should be added as a "Tip" or "Hint" to the future publications of the paper for clarification, particularly for those of use that are still newbies to all this.)
Anyway, I did try using similar "die" coding that Jason had provided me with my earlier problem, but I get a blank screen every time. So, I must not be incorporating the code correctly.
Any thoughts on how to figure out what I need to do to correct this problem are greatly appreciated. Thanks in advance.
On line 25 of the WA_Universal_Email/WAUE_test1_1.php file, I can see that you have only selected the serverDirectory for the attachment:
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]  ."");
double click the Universal Email server behavior. On attachments tab, select the code that is already there for the server directory and copy it. Then click thye lightning bolt and select the server file name name.
Place your cursor at the beginning of the server file name code and paste the server directory code.
When you are done, line 25 should look like:
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]  ."".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]  ."");
paputxi
Jason, after correcting the mistake it still doesn't work. I'm including the code for your review.
I am wondering if the validation on the file field is somehow causing the problem. When I created the file field in FB, I did not indicated that I wanted validation, i.e., I left the required checkbox unchecked. However, in the example I provided it shows that a file IS required and, if I don't select a file, it tells me I need to select one. So, it is validating that field even though I did not request it nor want it to be validated. Just a thought, but in any case I need to find out how to get the validation removed from that file field in addition to getting a file uploaded.
To remove validation, in the Server Behaviors list, select the Server Validation server behavior and click the Minus button to remove it.
To trouble shoot the upload, change line 25 in the WAUE_test1_1.php file:
die("".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]  ."".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]  ."");
paputxi
Hmmm. I get a blank screen after clicking the Submit button. I tried this both in Firefox and IE. I noticed this same thing yesterday when I was trying to debug similar code, which is why I ended up write to the forum. This approach did work the other day when you were helping me. So, I'm perplexed why it doesn't work now. Any thoughts??
And, BTW, thanks for tell me how to delete the validation behavior.
hmmmm, that is strange.
lets try changing line 25 to:
die(WA_DFP_AllUploadsDebug());
also add:
error_reporting
(E_ALL);
at line 1 of the test1.php page.
paputxi
OK, the results are below. I know I can write into the "attachments" folder as I also created a test2.php file in this same website, where I used DW rather than FB to create the file field and it works ok.
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
Ughh. I was missing the forest for the tree's.
The forms encoding type needs top be changed to multipart/form-data.
change:
html:
<form class="NewFromBlank_Default" id="Default_NewFromBlank_Default" name="Default_NewFromBlank_Default" method="post" action="test1.php">
html:
<form action="test1.php" method="post" enctype="multipart/form-data" name="Default_NewFromBlank_Default" class="NewFromBlank_Default" id="Default_NewFromBlank_Default">
paputxi
All that did was to remain on the form. It left the value I had in the Info field, but cleared the file field. The form was never submitted as I never got any email.
Note: I did not remove the "die" or additional PHP coding you had me enter earlier. Also, I deleted the validation per your earlier comment. I was hoping that would make a difference but it didn't.
can you send the most recent version of your page so I can take a look at the currant state of the code.
