Data Assist Wizard with multiple tables
Thread begun 10/21/2009 12:20 pm by chadhuskey391193 | Last modified 10/23/2009 4:03 pm by Jason Byrnes | 4766 views | 7 replies |
chadhuskey391193
I've got a bit of a newbie question here so please be patient. I don't have any PHP experience and very little MySQL, but I'm working on that :)
I have an Items table with these columns:
ItemNumber (key)
ItemName
ItemDesc
ItemPrice
MSRP
and a Color table with these columns:
Color_ID (key)
ItemNumber (matches the ItemNumber field in the Items table)
Color
I've created both tables using MySQL Administrator and I haven't created any relationships between them.
Basically the Color table stores the color information for the items in the Items table. We have several products that have multiple colors so that's why I set up a separate table for that. I'll need to create more tables for things like sizes and manufacturer, but I wanted to get two tables working and then go from there to make sure I understand the process.
When I step through the data assist wizard I can only define a connection to one table as far as I can tell. How would I use data assist to pull data from more than one table at a time?
Thanks!
When running the data assist wizard, you cannot use multiple tables.
You need to create this part by hand using the data assist server behaviors.
in your case, the colors table should be set up like:
colors:
colorID
colorName
then you would have a third table to use as a linking table:
prodColor:
prodColorID - Primary key
prodColorColorID - foreign Key relation to colors.colorID
prodColorProductID foreign Key relation to items.ItemNumber
on the product insert page crated by DataAssist, create a new recordset:
SELECT * FROM colors to return all colors
add a checkbox to the page, and set the checked value to come from the colorID column of the recordset you just createed:
<input name="color" type="checkbox" id="color" value="<?php echo $row_rsName['colorID']; ?>"><?php echo $row_rsName['colorName']; ?>
Then use the Manage relational Table server behavior.
chadhuskey391193
Thanks for the reply. I'll look into the method you've described here.
I also talked to a friend of mine that does DB programming and he suggested maybe using a view. I don't see the option to use that in data assist, only a table, but I thought I'd ask to make sure that wasn't an option also.
Thanks again for the help!
The Data returned from a view is read only, you cannot update or insert data to a view.
Since the idea with DataAssist is to create pages to manage the data in your database, you wont be able to use a view.
chadhuskey391193
I finally have some time to actually sit down and work on this today. A couple of questions:
1. If I add more options, such as size, can I still use one table to link them together? Such as
ProdOptions:
ProdOptionsID: Primary key
ProdOptionsColorID: foreign key relating to colors.colorID
ProdOptionsSizeID: foreign key relating to size.sizeID
ProdOptionsProductID: foreign key relating to Items.ItemID
So if ItemA comes in ColorA, ColorB, SizeA, and SizeB there would be four rows in the ProdOptions table to cover the combinations?
2. Also if I wanted to do a drop down menu on the page instead of a checkbox how would that be handled?
I feel like I'm a little slow getting started on this because I'm totally new to MySQL/PHP, but I do feel like WA has put out really good products and I have to say the level of support on the forums has been excellent.
I've had some problems making my way through the tutorials, but I don't know if that has to do with my lack of experience with a new work environment. I did manage to make it through them though and they were very helpful in the end.
Thanks!
colors:
colorID
colorName
prodColor:
1) yes, you could manage the multiple options that way.
2) The manage relational table server behavior does not support select lists. you would need to use a checkboxes.
chadhuskey391193
Thanks for the response.
I would like to be able to use drop down selections, so if possible please point me in the right direction to accomplish this.
I had setup some static pages on our site prior to purchasing WA and used Paypal standard cart which has the option of the drop down selection that I like. Here's a link to the page I've setup on our current site:
2009demobikes2.html
The second bike down the page has the type of drop down I'd like to have generated.
Could this be accomplished via eCart, or would it still be done with DataAssist or another method?
From what I can tell all of the data sorting/selecting should be done prior and then eCart is just used to add the item to the cart, but I wanted to make sure.
I think I'm on the right track with the database structure thanks to your advice, I just want to make sure I can get my head around how to do this before I get too far along and have to back track.
On the download page eCart, see the eCommerce Recipes section. One of the recipes deals with Database Driven product options and will help you with creating a select list in the eCart pages.
