Delete record??
Thread begun 10/21/2009 11:41 am by dean248377 | Last modified 10/22/2009 11:49 am by Jason Byrnes | 2132 views | 3 replies |
dean248377
Delete record??
I would like to use one of WA images as a delete button. How do I go about this. I have a repeating table all set up to dispaly my records. In the last cell I have both the edit image and the trash can image.
What would the process be here. I've never been sure about how to make an image a button but i assume that is waht is needed. Every time I try this I run into issues with lining up the edit image and the trash can. One sits at the top of the cell and the other at the bottom. This also makes the entire table row to tall. Basically evertime I try it I screw everything up, the layout and it wont delete!!
Any help would be apprieciated.
Dean
In this case, it is not actually an image button, it is an image that is a link to the delete page. The link will pass a querystring variable that is the ID oft he record to delete::
<a href="Delete.php?ID=<?php echo(rawurlencode($row_rsname['ID'])); ?>" title="Delete"><img border="0" name="Delete<?php echo(rawurlencode($row_rsname['ID'])); ?>" id="Delete<?php echo(rawurlencode($row_rsname['ID'])); ?>" alt="Delete" src="WA_DataAssist/images/Pacifica/Refined_trash.gif" /></a>
dean248377
can this delete page be a blank page with a redirect so the user never sees anything but the page they were on refresh. If so... How?
dean
Sure. In the delete record server behavior, set the Redirect after delete to go back to the results page.
