No thumbnail delete
Just noticed there is no thumbnail deletion going on. I've included unlink() within your delete script but lets face it, if I have to use that, then there isn't any point in using your script. Am I using this stuff correctly?
I'm not sure I follow, the Delete file server behavior will delete files from the server.
Where did you need to use unlink()? I will need more information to understand what your problem is.
It does delete files from the server. The image files. But not the thumbnail files. It doesn't matter anymore. Thanks anyway.
you will need to add a separate delete file behavior for each file you wish to delete. If there are thumbnails, and large images, then there needs to be a delete file behavior for each of the thumbnails and one for the large image.
