Flash Error
Thread began 10/21/2009 9:45 am by njewett222247 | Last modified 10/21/2009 1:07 pm by Jason Byrnes | 762 views | 1 replies |
njewett222247
Flash Error
I get the attached error when accessing help form DATAASSIST. The wf_.... file is in found in this path and the path is not complete so I can't adjust my settings. How is the help file using flash in any case.
Question #2
In the search page options: Where do I dfind the definition of "Criteria" and then Includes. I need to understand the includes so I know what files to upload.
Nick
This is most likely due to a problem with your Flash security settings. You can make changes to the Security settings at the following URL:
settings_manager04.html
You should add the following folder to the Always Trust Files From These Locations list:
Hard disk: Users: <Your User Name>: Library: Application Support: Adobe:
The Includes Criteria creates a where clause using using LIKE. For example:
SELECT * FROM tblname WHERE column LIKE '%as%"
this would return "flash" and "assist"
The files needed for database search are in the WADbSearch directory.
