Some content not showing up
Thread begun 10/20/2009 11:38 am by toby379423 | Last modified 12/02/2009 12:03 pm by Jason Byrnes | 11711 views | 26 replies |
toby379423
Hi there,
I've been working on the store section of this site locally, got everything working great & then uploaded everything (including the database) and changed the settings in the localhost.php file. For some reason the only thing that shows up is the background, header & part of the top nav:
PowerStore200/
Any ideas why?
If you view source of the page, you will see that it ends with:
<li class="parent"><span><a href="/PowerStore200/Products_Results.php">Products</a></span>
No database selected
this suggests that the database being used by the localhost.php file does not exist on the server.
toby379423
thx I'll check it out!
toby379423
I've done this before so this is a bit frustrating...
I''ve checked the database & everythng seems to be fine.
I've looked at the localhost.php file and everything seems to be correct:
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_localhost = "localhost";
$database_localhost = "triangle_store";
$username_localhost = "triangle_shoosh1";
$password_localhost = "XXXXXX";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
Since this is not at the root folder do I need to change $WAGLOBAL_remoteRoot = "/"; in the WA_Globals file to /PowerStore200/ maybe?
Also, in Dreamweaver, when I try to test the connection by clicking the database tab, I get "An unidentified error has occurred".
Anything else I need to check?
can you double check with the host that using "localhost" in the connection for the mysql server is correct.
Does the "triangle_store" database exist on the remote MySQL Server or you local mySQL server?
It needs to exist on the remote my SQL server.
Yes, $WAGLOBAL_remoteRoot should be set to /PowerStore200/
$WAGLOBAL_remoteRoot = "/PowerStore200/";
toby379423
Apparently, the database wasn't assigned to the domain so everything's good on that front, but another thing I'm noticing is that the search function seems to be a bit sporadic. Some items show up fine, while others don't.
It seemed to work fine when I was testing locally. Any ideas why?
can you give some more specifics on the problem. do you have a link where I could see the issue demonstrated.
toby379423
Sorry about that,
PowerStore200/
The search function on the top nav is what I'm talking about, depending on the titles you put in, it seems to produce unpredictable results. Some titles show up fine, while others are way off.
I'm sorry, I still need some more information.
can you give an example of a search term that is not working correctly for you?
toby379423
Sorry for the delay! Got a bit busy...
The search function seems to work with Intimate Invitation, Boundaries, and Tribade, but By Appointment Only & When Ginger Met Nina come up with other titles when I type in for example "By Appointment Only" or "When Ginger Met Nina". Is there a way to correct this?
