no luck the file does not upload
Thread begun 10/20/2009 9:28 am by danw391573 | Last modified 10/20/2009 2:38 pm by Jason Byrnes | 6012 views | 10 replies |
danw391573
I followed the step by step guide on Creating a digital File upload in Digital File Pro 2, no luck the file does not upload to server. When making a path to Upload folder field the fold is in the root with all of the files, so I put the folder name is that correct ?
anonymous
Hi there,
Did you remember to set the permissions of your folder on the server?
Also, if the permissions are correct... could you post the code here so we can see what is going on?
Thanks,
Brian
danw391573
Yes I did set the permissions
Yes, I did set the permissions of the folder I want to upload to on the server.
I have attached the file.
Thanks for the help
To trouble shoot, add the following code at line 1:
error_reporting
(E_ALL);
the go to the bindings tab and expand the WA Uploaded Files Global Status group and bind the debug info to the page.
Post back the debug info results after performing another upload test.
danw391573
Status object: WA_UploadResult1
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
This means the upload is not being triggered
It may be that the host has disabled the $_SERVER["HTTP_REFERER"] variable which is causing the Currant Page Submit trigger to fail.
Try using the any form post trigger instead.
danw391573
This what I get now still not uploading
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
Your page has two separate forms:
html:
<form id="form1" name="form1" enctype="multipart/form-data" method="post" action="">
<label>Upload File
<input type="file" name="Upload" id="Upload" />
</label>
</form>
<form id="form2" name="form2" method="post" action="">
<label>
<input type="submit" name="submit " id="submit " value="Submit" />
</label>
</form>
The file element is in one form, the submit button is in another.
When you click the submit button, it will only post elements that are a member of that. you need to combine the two forms into one:
html:
<label>Upload File
</label><br />
<label>
</label>
</form>
danw391573
Thank You!
Thank You Thank You Thank You it works now :)
danw391573
Will not upload video files
Will not upload video files, why?
I don't have it set to images only.
