Large Space on Result Pages
Thread begun 10/19/2009 1:11 pm by reseller218363 | Last modified 10/27/2009 7:07 pm by Eric Mittman | 5908 views | 8 replies |
reseller218363
I need help resolving an issue with dataAssist. I’m currently using CSS Sculptor3 to build my template. However, all pages created using DataAssist Ex. Result page has a large empty non removable space causing the result page to fall to the bottom of the page.
Sharach
Most likely a css problem. Please post a link sop I can examine the css on the page.
reseller218363
Hi Jason Byrnes,
Per your request, I have enclosed a .php zip copy of the results page and also an image of the the page itself.
Sharach
I need a link to your site where I could view the page in a browser to examine the css.
reseller218363
DataAssist Result page
Sorry Jason, I'm working on my local station. The site is not live, However, I'll upload it tonight and make the link available to you.
PS. can you connect via remote? if so please reply.
thanks
Sharach
reseller218363
CSS form Builder
I’ve a working checkout page. However, I am unable to configure a checkbox that will auto copy the billing info to the shipping form fields; only if the information is the same. Tonight I started reading about CSS Form Builder. It seems to me that using CSS Form Builder to build a checkout page will help me solve the copy problem. So I decide to create a new checkout page using CSS Form Builder. When I got finishing creating the checkout page I was bit confuse about the dynamic text Field and the dynamic List/Menu and all the dynamic names and script that was created by CSS Form Builder.
What I’m trying to say is I’m not sure what to do. I am afraid to continue because my database table is already setup with data type and it is link to the confirm.php page and checkout_success.php page. And I notices that CSS Form Builder has created it own data type name for the dynamic field.
Now, will my checkout page work if I rename all the field created by CSS form builder and match the same field name as with the old checkout page?
I don’t understand why the creator of the extension did not link the wizard with database so that the naming of the field could come from the database table.
Please advised
Sharach
When it comes to your checkout page with the checkbox to make the shipping the same as the billing eCart does this for you automatically. If you run the wizard and specify on the first page that you will be offering shipping service then the checkout form that is generated will have this checkbox to make the shipping the same as the billing.
If you wanted to after the fact you could use CSS Form builder on this form to modify or edit it. I hope this clears up some confusion on how you could accomplish this. Please post back if you have any further questions.
reseller218363
CSS Form Builder
When it comes to using eCart shipping option, do I've to complete the other setting that relate to shipping? Also, If I use CSS Form Builder to edit and add new field type to the checkout page created by eCart how will I overcome to the new field name created by CSS Form Builder.
thanks
Sharach
Using the checkout wizard will create the checkout page for you along with the others needed in the checkout. If you do not need these other pages you can discard them after the fact.
For the Form Builder question you should not have to worry about the names if you are just updating the form. Please post back with some more info on this so I can get a better understanding of what the problem might be.
