Customer Credit
Thread begun 10/19/2009 11:51 am by robert329616 | Last modified 10/21/2009 1:26 pm by Eric Mittman | 2415 views | 3 replies |
robert329616
Customer Credit
Hello All.
I am wondering if there is a way with power store or ecart to manage customer credits.
When a customer returns an item, we are offering store credit only. How can I set it up so that the customer can apply the credit to their next purchase? Is this handled by power store already? We would also like to have a expiration date (one year) applied to the credit.
Thanks.
Rob
Having a system in place that allows for customer credit is possible but it is not a supported feature of either the PowerStore or eCart so the implementation would be custom. How it would be implemented would depend on how exactly you wanted the user to use the credit and interact with the site.
If you have things setup so that you manually apply a credit to the user you could have a check of the user record for this credit. Then during checkout allow them to apply it to the order. If they do then you would need to store the credit in a session variable, then create a discount rule that will discount the amount of the session variable.
This is just the start of this type of a setup though and there are some other scenarios you would need to account for. Like the fact that you would not want to send the user to the merchant gateway if the credit were larger than the amount of the purchase.
This is not something that I will be able to give you a detailed step by step guide on but I can try to assist you with any questions that you may have about this or just in general.
robert329616
Eric,
Thanks for the overview. I will give it a try and see how it goes.
Regards,
Rob
Sounds good, give things a try and let us know if you have problems with any part of it and I can see what I can do to help you out.
