Email Attachment not received
Thread begun 10/19/2009 11:27 am by massimo173451 | Last modified 10/20/2009 3:55 pm by Jason Byrnes | 5704 views | 7 replies |
massimo173451
Hi there,
I have tried to send the email with file attached, but when open the email is received normally (only the text) but the attached file no why this happen?? (On the server the file is normally upload in the directory specified).
Massimo
Have you seen the 'Sending Email Attachments with Digital File Pro and Universal Email" tutorial in the how to section of the Digital File pro support page:
digital-file-pro/
if you are still having problems, compress you file and the WA_UniversalEmail folder into a zip archive and attach that to your reply.
massimo173451
Hi Jason,
Follow the file as your request, just another thing when use the form in the UE then set in GENERAL TAB choosing Submit button trigger in the form (WA_DFP_UploadObj.Form("Submit")), if edit it again the previous value stored is reset to default (Button: Submit pressed). I hope this help you to find a solution.
Massimo
Yes, the trigger will need to be reset when you edit the Universal Email server behavior.
Please send a copy of the page you have applied universal Email to so i can look at the code.
massimo173451
Hi Jason in attachment the file for create email.asp.
Massimo
The attachement is set to only the upload path, it does not include the server file name:
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr(Server.MapPath("../public/upload")) & "")
On the attachments tab, click the lightning bolt next to value and select the Server File name variable from the WA Upload Files (File Field) group. Then place you cursor in front of the code that is added and paste the following:
../public/upload/
massimo173451
I have changed the code but without positive response follow the code used:
'Attachment Entries
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"../public/upload/" & cStr(WA_DFP_UploadStatus.Item("WA_UploadResult1").serverFileName) & "")
try using:
'Attachment Entries
set WA_MailObject = WAUE_AddAttachment(WA_MailObject, Server.MapPath("../public/upload/" & cStr(WA_DFP_UploadStatus.Item("WA_UploadResult1").serverFileName) & ""))
