Shipping cost based on product category
Thread begun 10/18/2009 2:52 pm by tolushayoo193471 | Last modified 10/23/2009 1:17 pm by Eric Mittman | 5874 views | 9 replies |
tolushayoo193471
Hi
Please how can I generate shipping through database lookup , I want the shipping cost to be based on product category, am not sure if it's possible, or how i can use ecart to implement these but i prefar non stress mathod. how can these be implement in powerstore thanks
The first step in getting something like this implemented is to clearly define exactly what you would like to have occur for the charges. Please explain as best as you can the specific circumstances of the shipping charges and how you would like it to work from the perspective of the user on the site. With a little more description we will be able to better assist and advise you on how to implement this.
tolushayoo193471
Thank you, I dont have UPs account, I intend to have my ow shipping charge base on product category. eg. if some order baby cot bed which product id is = 1, then the shipping cost will be £16.00 but if some order a spoon whcih product id = 2, the shipping cost will be £1.50.
I hope you understand. thanks
Thanks for the info on the items, this is very helpful. This seems like it would be a good fit for some basic flat rate shipping costs. However since the shipping is something that is applied to the total cart and not just an item in the cart I'm wondering how you would like to charge the shipping if the user has two different items in the cart? Would you have a special shipping charge depending on the combination of items? With this last part cleared up I can give you some specific pointers on getting this rule in place.
tolushayoo193471
Thank you, the postage is just a flat rate, no matter how many products in the cart of it it's just one is going to be the same cost. £9.00 for all item in the cart
In your example you mentioned
if some order baby cot bed which product id is = 1, then the shipping cost will be £16.00 but if some order a spoon which product id = 2, the shipping cost will be £1.50.
I'm curious how you would like to hand the situation where both items 1 and 2 are in the cart together. Would you combine these shipping charges as a single charge or would you have a special rate based on multiple products? If you just had flat rate shipping rules in the cart you could have the rules setup like this:
if item [1] is in the cart, apply a flat rate of 16
You would configure this on the shipping tab of the cart object. The problem is that if you do this for each item you have available and add more than one type of item to the cart you will only be charged the shipping from the last rule that is triggered because it is just a flat rate and not an accumulated value.
I think it would be best to have a column in the cart to hold the shipping value, then for the shipping charge you would base it off of the subtotal of the shipping value column. This way you would have a single flat rate for a particular item regardless of how many the user purchases, then if they had another different item in the cart the shipping charge would be added to the one for the first item. Please let me know how you would like to handle it and any questions you have about any part of the process.
tolushayoo193471
ok thank you i will go for your opinion, the one you mentioned, i will do it that way but I dont know how
This approach is not very straight forward and would require you to make some edits to your db and a few pages in the PowerStore. In order to make the edits in the PowerStore Admin you will need to have DataAssist. To make the changes on the other pages of the site you will need to use eCart.
The first step in getting the shipping charge setup like this is to ensure that you have a shipping column in your products table. You will need to add this in the db.
Next you will need to update both the product insert and product update pages in the admin area. The first page you should update is the insert page. On this page you will need to add a new form element to the form on the page, this will be where you enter the shipping amount. Next on this page you will need to update the DataAssist insert server behavior, on the list of columns that are being inserted into the db select your new shipping column and for the value use the lightning bolt icon to select the new form element you just added on this insert page.
The process is the same for the update page, you will also need to set the initial value of this new text field to come from the product recordset.
That is all for the admin pages, on the front end of the site you will need to update the cart object to have the new column and the products detail page. On this page you will update the add to cart server behavior, in the bindings set the ship column to the value from the recordset, this should be the same value you used on the update page in the admin area.
This will get you all setup for the shipping charge rule. For the rule you will choose total number of items > 1. Then for the calculation choose based on column subtotal and choose your ship column.
There are a few steps to this and it is kinda custom so I will not be able to guide you through the whole process but if you have any questions please let me know and I will be glad to help with whatever I can.
tolushayoo193471
Whao it's really long process, but with my previous idea i've used before, I went to the ecart object to divine these rule, I will just have flat rate.
RULE 1: PER ITEM ORDER CONDITION
"Total Number of Unique Items in Cart"
If the Total Number Of Unique Items in the Cart is [>] a value of [0]
CALCULATION:
Flat Rate {4.95]
AND (ANOTHER TRRIGER)
if Session variable Exists:
eCartCheckoutForm_shipping_country
Based On Session Variable Value:
If the session variable [eCartCheckoutForm_shipping_country] is [=] a value of [GB]
thanks for your help, if i dont want to ship to non uk address how can i trigger these
I think that I'm just not understanding the question, sorry. Would you like to alter your rules so that shipping to non UK addresses in not allowed? If so this is not something you would do on with your shipping rules but instead with your shipping locaiton select list on the checkout page. If I have got it wrong please correct me and let me know what you are trying to accomplish.
