error message when try to set session value
Thread begun 10/18/2009 10:37 am by JBWebWorks | Last modified 10/19/2009 9:59 am by Jason Byrnes | 3438 views | 3 replies |
JBWebWorks
have cookies toolkit 3.1.2 and DW CS4
in server behavior when trying to set session value get this error
JavaScript error while loading WA eCart 01Session.htm:
At line 746 of file "C:Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\Controls\Scripts\WATrigger.js"
WA_getDocumentDOM is not defined
I have tried deleting the WinFileCache file
also removed and reinstalled cookies toolkit 3.1.2
thanks for your help,
Jim Balthrop
Is setting a session value different from setting a session variable?
If so, how do you set a session variable?
Office Guy-172461
Maybe this previous post will help:
"We did some testing and this issue is caused by installing Cookies Toolkit 3.1.2 over eCart 4.5.0. If you download and install the latest eCart (4.5.1) which was just released, this should fix the issue.
Note: As with all extensions, make sure to uninstall the previous version before installing any updates. "
JBWebWorks
thanks
that fixed the error.
question- i am trying to set a session variable to insert into a user record to use to validate the user. I want the session variable to be a random string; what do i put in the value field of the set session value wizard?
Do you have SsecurityAssist?
If so, go to the bindings panel, click the plus button and select SecurityAssist - > Random Password.
Then in the set session value, click the plus button next to value and select the SecurityAssist random Password binding.
