SQL Syntax (Errors Using MySQL 5.0 Language PHP)
Thread begun 10/17/2009 1:30 pm by pipwax1390564 | Last modified 10/20/2009 5:03 pm by pipwax1390564 | 8808 views | 14 replies |
pipwax1390564
The Sql fail to submit. This is what I get when I test the page "SELECT * FROM employeelookup 0" I made this change to the code so that I can see the information
===========modified code===========
$query_Members = sprintf("SELECT * FROM employeelookup %s", GetSQLValueString($WhereParam_Members, "int"));
echo $query_Members;
exit;
$Members = mysql_query($query_Members, $Recipes) or die(mysql_error());
$row_Members = mysql_fetch_assoc($Members);
$totalRows_Members = mysql_num_rows($Members);
=============end modified code==============
======================entire code=================
<?php require_once('../../Connections/Recipes.php'); ?>
mysql_select_db($database_Recipes, $Recipes);
$query_EmployeeLookup = "INSERT INTO employeelookup SELECT employees_1.EmployeeID, jobs.JobID, jobs.JobTitle, employees_1.EmployeeFirst, employees_1.EmployeeLast, departments.DepartmentName, CONCAT(employees.EmployeeFirst,' ',employees.EmployeeLast) AS ManagerName, employees_1.EmployeeEmail, employees_1.EmployeePhone, employees_1.EmployeeMobil, employees_1.EmployeeCube FROM employees, employees employees_1, jobs, jobs jobs_1, departments WHERE ((((jobs.JobTypeID = jobs_1.JobID) AND (jobs.JobDepartment = departments.DepartmentID)) AND (employees.EmployeeJob = jobs_1.JobID)) AND (employees_1.EmployeeJob = jobs.JobID))";
mysql_query($query_EmployeeLookup,$Recipes);
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$WhereParam_Members = 'Where MemberID <> 0';
if (isset($WhereParam)) {
$WhereParam_Members = $WhereParam;
exit;
?><?php
$query_EmployeeLookup = "DELETE FROM employeelookup";
======================end====================
Any help would be greatly helpful
Why are you putting the where clause into a parameter for the members recordset?
The way I see it, the where clause will not change, right? parameters are used for variable data. data that may change.
why not just hard code the where clause with the select statement:
SELECT * FROM employeelookup Where MemberID <> 0
pipwax1390564
To the best of my knowledge i was following the instructions from the book. (Web application recipes) I just added the members table because I wanted to use thr module for a members system to a web community. However, when I think about it I only had to change the html lables?
The problem is the way the members recordset is created.
Do not use a parameter, just add the where clause directly in the SQL:
pipwax1390564
I am still learning this stuff, I am not sure where I would need to alter the code. Could you help me out? I am using Dreamweaver. My best guess is to double click the recordset and remove the Param and enter the Sql statement you gave me.
that is correct.
Double click the recordset, remove the parameter and add the where clause directly to the SQL statement.
pipwax1390564
Made Great progress these are the errors I am getting Now:
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/content/p/i/p/pipwax2/html/test/member_results.php on line 3
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/content/p/i/p/pipwax2/html/test/member_results.php on line 5
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/content/p/i/p/pipwax2/html/test/member_results.php on line 44
Here is Line 3:mysql_select_db($database_Recipes, $Recipes);
Here is Line 5:mysql_query($query_EmployeeLookup,$Recipes);
Here is Line 44:mysql_query($query_EmployeeLookup,$Recipes);
My best guess is that $query_EmployeeLookup should be $query_employeeLookup because the table in mysql is emlpoyeelookup but that did not work.
pipwax1390564
My database connection is newsfeed
could this be my problem?
the database name is DavidPippen
Did you edit the "Connections/Recipes.php" file by hand?
On the database tab, double click the recipes connection and click the test button. Does the connection test correctly?
Please send a copy of the Connections/Recipes.php file.
pipwax1390564
I will when I get home
