UploadFolder variable difficulties
Thread begun 10/17/2009 8:13 am by martin389853 | Last modified 10/19/2009 4:10 am by martin389853 | 4485 views | 7 replies |
martin389853
I did look to check if there was anything on this but nothing obvious that I could find.
You should be familiar with the code below.
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "". '$imageFolder' ."",
I have created the $imageFolder variable to hold the whole file link, eg. /images/johnsmithsImages/ where 'johnsmiths' will be another variable. Like this I store everyone's images in their own folder and summon up the link to the upload folder according to the logged-in user.
My problem is simply that no images are going into the folder. There are no errors being displayed like when I type the variable in incorrectly and if I write the exact folder location in, eg.
'UploadFolder' => "/images/johnsmithsImages/",
I don't have a problem. Am I writing sucky php? icon11.gif cheers.
anonymous
Martin,
Nine times out of ten, these problems are usually something simple... so I will start with simple. Did you remember to set the permissions of the folder once it was created?
If you are creating the folders manually and uploading the folders, you will need to chmod them to something like 0777 so they will have read and write capabilities. If you are allowing the folders to be created on the fly, then the parent folder will have to be assigned the recursive permissions of 0777 so that you can write within the folder and into all the child folders.
Cheers,
Brian
martin389853
Originally Said By: martin389853
  ... if I write the exact folder location in, eg.
I explained that I tested various things including if I am using the exact folder location as mentioned. The result of using the exact location was that I did not have a problem. Or to put it another way, the files were uploading. For this reason, we know that there is nothing wrong with the folder permissions.
Therefore, the problem must lay in my input of the variable.
Thanks for your response though.
martin389853
I have now used the same variable, eg. $imageFolder, in the same page, once as an echo statement and once also to read all the files in that directory, eg.
$dir= "$imageFolder"; //<--define the directory to view.
$files = scandir($dir); //<--read all the images into an array.
$im_num = 0; //<--reset image number before count
foreach ($files as $image)
if(substr($image, 0, 1) != '.') //<--Ignore anything starting with a period.
$image_size = getimagesize("$dir/$image");
//<--Get the image's size in pixels.
$file_size = round( (filesize("$dir/$image")) /1024) . "kb";
//<--Calc size in kb.
$im_num = $im_num - 1;
//<--count every image in the folder.
$rev_im_num = $im_num*-1;
//<--Display the info.
echo "<tr>
<td>$rev_im_num</td>
<td>$image</td>
<td>$file_size</td>
</tr>";
So now I see the variable as a link so that I know how it looks. I also see if the link works because I get a list of the images in the file with file size. This means that the variable element is the correct file location. Knowing this and knowing that using the link (not the variable) directly in the WA_UploadResult script works, I must conclude that there is nothing wrong with the variable or the folder permissions.
I therefore conclude that WA_UploadResult is taking my variable and ... eating it. Bad boy WA_UploadResult. Only you guys know what your extension is doing and how it is doing it so only you can tell me why your script is turning my variable into air. thanks for listening.
anonymous
Martin,
After closer look, you actually have an error in your PHP
Notice, you have single quotes around your variable... that tells PHP to show the text exactly as it is typed and not process it as a variable.
Your variable should actually be this:
'UploadFolder' => "". $imageFolder ."",
You could enclose the variable inside double quotes because that tells PHP that processing is required inside the string. The only time where PHP processes something inside single quotes is inside a query statement.
Best regards,
Brian
martin389853
Thank you kind sir!
I do get a little mixed up, especially when I've been looking at the same stuff for some time. Your correction there was exactly the ticket. Its on page 32 of my 'Php and Mysql' manual, single vs double quotation marks! haha.
I was thrown because I originaly wrote : 'UploadFolder' => $imageFolder,
Writing "". to me is saying 'Start string, End string, concatenate'. Starting and ending a string without a value is like saying 'nothing' and why would you concatenate nothing to that?
My problem is solved though, so thank you. However, if you were to enlighten me any further with an explanation of why you concatenated the double quotation marks, that would be a bonus. Again, many thanks.
anonymous
Hey Martin,
I don't always do that practice, but a lot of programmers like to concatenate that way so they are explicitly ensuring that nothing is before or after what they are processing (especially when setting a lot of variables). The empty quote strings, in other words, will guarantee that there is nothing before or after.
Brian
martin389853
I like your style. A trend is born :)
Thx again.
