WADAProducts Recordset won't open in DW Bindings Panel
Thread begun 10/16/2009 2:56 pm by jstoler155201 | Last modified 10/19/2009 11:24 am by Jason Byrnes | 2708 views | 3 replies |
jstoler155201
The WADAProducts recordset, the main one, works just fine on the testing server and the client host server, but the bindings panel won't open.
Local and host running PHP 5.2.6 and MySQL 5.0.41 local, 5.0.87 host.
Throws MySQL Error# 1064 "..errors in syntax..near.."at line 2.." when I try to open the panel.
I can open the Server Behavior part just fine, and I did change the product table by adding a field in the DB only, and am needing to add some more.
Any advice, please.
Thanks,
Jay
the recordset is too complex for Dreamweaver to parse.
a work around is to change the code to a simple recordset, use the binding panel, then change the code back.
For example, on the product resuts page, look for the following:
$query_WADAProducts = "SELECT *, (ProductStock - (SELECT Coalesce(Sum(DetailQuantity),0) FROM orderdetails INNER JOIN orders ON OrderID = DetailOrderID WHERE DetailProductID = ProductID AND OrderDate > ProductUpdateDate)) AS NumLeft, (SELECT MAX(ProductPrice) FROM products as prod2 INNER JOIN productoptions ON productoptions.ProductID = prod2.ProductID WHERE  productoptions.GroupingID = products.ProductID AND prod2.ProductLive <> 0) AS TopPrice, (SELECT MIN(ProductPrice) FROM products as prod2 INNER JOIN productoptions ON productoptions.ProductID = prod2.ProductID WHERE productoptions.GroupingID = products.ProductID AND prod2.ProductLive <> 0) AS BottomPrice FROM products  LEFT OUTER JOIN productcategories ON ProductCategoryID = CategoryID WHERE ProductLive <> 0 AND COALESCE((SELECT GroupingID FROM productoptions WHERE productoptions.ProductID = products.ProductID LIMIT 1), ProductID) = ProductID";
and change it to:
$query_WADAProducts = "SELECT * FROM products";
after you have made the necessary changes using the bindings panel, change the recordset back to the priginal.
jstoler155201
That is what I need to know
Thanks, Jason. That will do what I need. Never thought to cut and paste and substitute a simple recordset. Great workaround.
Best,
Jay
You're welcome.
