Request Form Error
Thread begun 10/16/2009 2:05 pm by massimo173451 | Last modified 10/16/2009 3:45 pm by Jason Byrnes | 3230 views | 1 replies |
massimo173451
Request Form Error
After include the Digital File Pro 1 + with Universal email, when try to send the email I get this error:
Request object error 'ASP 0207 : 80004005'
Cannot use Request.Form
/email.asp, line 107
Cannot use Request.Form collection after calling BinaryRead.
The snippet code is the follow:
set WA_MailObject = WAUE_SendMail(WA_MailObject,MailAttachments,MailBCC,MailCC,MailTo,MailImportance,MailFrom,MailSubject,MailBody)
set WA_MailObject = nothing
end function
if ((cStr(Request.Form("Submit")) <> "")) then <----- line 107
'WA Universal Email object="AspEmail"
'Send Loop Once Per Entry
WA_Universal_Email_1_SendMail("info@tessyacconciature.it")
'Send Mail All Entries
if ("email_confirm"<>"") then
Response.Redirect("MainMenu.asp")
end if
end if
The Url Link is email.asp
Where is the mistake in this code?
Regards:
Massimo
After applying Digital File Pro to an asp page, you can no longer use the Request.Form collection.
DFP Creates a WA_UploadEObj.Form collection to use instead.
The error is occurring on the Universal Email trigger.
Double Click the Universal Email server behavior, click the lightning bolt next to trigger and select the submit button from the form collection to have the trigger code generated correctly.
massimo173451
Attachment file not received
This post has been deleted.
