Sometimes FB does not include all code
Thread began 10/16/2009 12:44 pm by chuck186871 | Last modified 10/16/2009 7:18 pm by Eric Mittman | 1172 views | 1 replies |
chuck186871
Sometimes when I wish to make another form with FB in a new page, the second form is not finished properly. Line terminators are missing as are necessary codes. For example,
INSTEAD OF:
if (ValidatedField('test','test')) {
if ((strpos((",".ValidatedField("test","test").","), "," . "14" . ",") !== false || "14" == "")) {
if (!(false)) { . . .
I GET:
if() {
if(!false)) { . . .
If I shut down DW, remove the cache file, return to DW, then I can create a form successfully.
But, it occurred to me that it is also possible the problem may be related to the fact that I create a new file which DW wants to save as HTML, but I save it as PHP. I then create my form in this new file. If I view the code, DW hasn't validated it as it has not added color to the code.
I haven't run extensive tests to confirm my theory but I'm thinking the real problem is that I'm creating a new PHP file that DW hasn't yet recognized as PHP, but because it has a PHP extension, WA_FB runs, but misses generating all the necessary code. This is just my guess from empirical observations. But it is an annoying problem for me for which I have workarounds. However, it seems that none of this should be happening. I'm not sure if it is DW or WA_FB or what.
The html pages being saved as PHP may have an effect on this. As a test could you do the same as you are doing now and create a new PHP page instead of resaving an html page? If you get the same result this way it indicates that there is an issue that will need to be looked into more closely. Please get back to us with what you discover.
