Page not posting Validation window on submit
Thread begun 10/16/2009 11:33 am by doug71213 | Last modified 11/06/2009 9:34 am by doug71213 | 2365 views | 2 replies |
doug71213
When I submit the form with the validation code, I am able to continue to the next page without seeing any required validation message on our page at order_form.asp. This page and attempted validation is on a form that uses an add to cart button. Please advise.
You have some form elements that use invalid names.
When naming a form elements, the following naming rules apply:
1) You may only use alpha numeric characters, the only exception is the underscore "_".
2) The name cannot contain any spaces or other special characters.
3) The name cannot start with a number.
the form elements "zip code" and "email address" contain illegal spaces. The spaces are causing the client side validation to throw javascript errors.
doug71213
Perfect, thanks! for the easy resolution!
