errors
Thread begun 10/16/2009 6:27 am by i.edwards384429 | Last modified 10/19/2009 7:11 am by i.edwards384429 | 3161 views | 2 replies |
i.edwards384429
errors
Hi
just tried applying a template and received errors so I went back and tried the core file
I get the following error
Warning: require_once(Connections/localhost.php) [function.require-once]: failed to open stream: No such file or directory in C:\wamp\www\1stmodelagency\users_Registration_Simple.php on line 7
Fatal error: require_once() [function.require]: Failed opening required 'Connections/localhost.php' (include_path='.;C:\php5\pear') in C:\wamp\www\1stmodelagency\users_Registration_Simple.php on line 7
This is on my test vista ultimate system running the latest version of wamp.
If I double click on the database connection and try test button it connects ok
I'm searching for the correct word here but I think
Help!!! somes it up
cheers
Ian
make sure you have correctly set the "$WAGLOBAL_Root_URL" variable in the WA_Globals.php file.
where you are storing the user registration files at:
the $WAGLOBAL_Root_URLshould be:
$WAGLOBAL_Root_URL = "http://localhost/1stmodelagency/";
i.edwards384429
update
that fixed it
Ian
