How to use "Inner join" without recordset disappearing??
Thread begun 10/16/2009 1:17 am by kakadong | Last modified 10/16/2009 2:18 pm by Jason Byrnes | 2779 views | 3 replies |
kakadong
I use the WADA wizard to build a backend ,
and I have to use inner join to make the data more meaningful ,
but , when I try to change the code in results.php
SELECT
PrimaryID, pCompanyID, ShortName, Name, pLandInOut_ID, pNowEnd
FROM
primary_insuarance_table ORDER BY pCompanyID ASC
into
SELECT
PrimaryID
, primary_insuarance_table.pCompanyID
, company.CompanyName
, primary_insuarance_table.ShortName
, primary_insuarance_table.Name
, primary_insuarance_table.pLandInOut_ID
, land_in_out.LandName
, primary_insuarance_table.pNowEnd
, now_end.NowEndName
FROM
backend.primary_insuarance_table
INNER JOIN backend.now_end
ON (primary_insuarance_table.pNowEnd = now_end.NowEndID)
INNER JOIN backend.land_in_out
ON (primary_insuarance_table.pLandInOut_ID = land_in_out.LandinOutID)
INNER JOIN backend.company
ON (primary_insuarance_table.pCompanyID = company.CompanyID)
the recordset in serverbehavior panel disappeared....
and the DAsearch got a "!" next to it ...
i think it must because the recordset is disappeared.....
So , please help me to solve this ...
and i have to do the same change in details.php and delete.php ...
and I will put the original files ....
if more information is needed ...
please tell me....
Using an INNER JOIN Should not cause the recordset to disappear. I see no problem with the SQL Statement you have provided.
What happens if you click the test button before clicking the OK Button? Does the SQL test OK.
Sometimes I have seen Recordsets disappear in Dreamweaver for no reason, often saving the page, closing it and reopening it will bring the recordset back into the list.
As for the exclamation mark next to DataAssist Search, the red Exclamation really only means "there *may* be a problem" when Dreamweaver inspects the code, it sees something that is "not quite right". It means the page May run smoothly, or it may not. If it doesn't, the nit's time to worry about the exclamation mark, if it does, ignore it.
kakadong
I got the problem OUT !!
NOW, I know what's wrong with it......
when i click the "test" everything goes well but when I click ok .... recordset disappear...
if the recordset disappear.. I can't update the DAsearch.... because the wizard is not reenterable....
So... I try it again....
but this time I find that Dreamweaver make the SQL "Select #@%$^# " into one line but usually for the better understanding ... I will turn my code into several ines.... like
"select
from
that's the problem ....
thistime, I make the SQL code into one line.....
the recordset didn't disappear ....
WOW... Amazing...
SO... I solve it .....
But Still thanks for replying so fast ...
Hmmm, interesting, I thought that may be linked to the problem, so tested it on a few queries on my end did not have the recordset disappear.
I discounted it as the cause when I couldn't reproduce the problem.
But now we know :)
