eCart tutorial database not creating tables
Thread begun 10/15/2009 8:30 pm by corrietrexler372741 | Last modified 10/15/2009 9:25 pm by corrietrexler372741 | 2329 views | 2 replies |
corrietrexler372741
In the eCart tutorial I created the blue sky music database. I go to PHPMyAdmin and I can see the database was added. I then went on to the steps for creating the tables in the Windows>run>cmd and it goes thru the whole process but when i go back to PHPMyAdmin it says the blue sky music database has no tables. I am using wamp and changed my command lines to this:
cd \
cd C:\wamp\bin\mysql\mysql5.1.36\bin
It then opens up mysql folder where I copied the blue_sky_music.sql to.
then i type in these commands:
mysql -uUser -pPassword blue_sky_music <blue_sky_music.sql
and then it will go through a bunch of processes and when its done I type 'exit' and close out of the cmd.
I just don't know what it is that i am doing wrong. I am using wamp so I am trying to adlib these directions as best as I can.
Office Guy-172461
See if these articles help:
Exporting and Importing a database using phpMyAdmin
150/
Creating a dynamic site definition in Dreamweaver
151/
The blue_sky_music.sql file will create the database and tables for you automatically. It is a standard text file so you can look at it to see what it will do.
Did you download all of the support files from your download section?
corrietrexler372741
Awesome!!! That was soooo easy! I am slowly making my way through the tutorial!
Thanks again!
