Multiple Configutation Floater error messages DW CS4
Thread begun 10/15/2009 3:48 pm by jhood-fysh78990 | Last modified 11/09/2009 12:19 pm by Jason Byrnes | 6530 views | 5 replies |
jhood-fysh78990Beta Tester
Greetings,
I reinstalled my WA_Cookie software and got the following error message:
The following JavaScript error occurred:
At line 25 of file "DW CS4 install location \configuration\Floaters\WA_Memento.js":document.remindersWP.document.track has no properties.
I clicked ok then got 5 more errors as follows:
1. Unable to find file WA_Memento.htm in the configuration/Floaters directory. The floater will not be shown.
2. Unable to find file WA_SiteTools.htm in the configuration/Floaters directory. The floater will not be shown.
3. Unable to find file WA_SiteTools_Progress.htm in the configuration/Floaters directory. The floater will not be shown.
4. Unable to find file WA_SiteImport_Progress.htm in the configuration/Floaters directory. The floater will not be shown.
5. Unable to find file WA_SiteImport.htm in the configuration/Floaters directory. The floater will not be shown.
After which the DW crashed. I uninstalled all the WA tools I had. I DW workspace loads after the 5 messages. I no longer get the JavaScript message.
What is going on?
John
In Dreamweaver go to Window -> Workspace Layouts -> rename '<Your layout Name>'
the with Dreamweaver closed, try deleting the Dreamweaver cache File form the users configuration folder:
I did as you suggested
Greetings, thank you for the reply.
I did as you suggested including deleting the cache file but I still was getting the same error messages, but DW did load. The extensions had already be uninstalled, so I reinstalled several, including the ones that were seemingly giving me the error messages.
Now when I run DW CS4, I still get 2 error messages related to site import (see original post).
Yes, now the floater displays as well.
Any other suggestions?
John
Try following step 2 on this page:
146/
pacaron382332
Popup:Unable to find file WA_Mem....... (continued)
146/
I have the same problem.. Deleted the File Cache file... Restarted DW.. No change.
Getting popup when starting DW " Unable to find file WA_Memento.htm in the configuration/Floaters directory. The floater will not be shown."
Using: DWCS4 Mac
What does it take to get rid of the popup?
Ron
In Dreamweaver, go to Window -> Workspace Layouts -> Reset '<layout name>'
Then close Dreamweaver and delete the Dreamweaver cache file again.
