Can Security Assist Do The Following...?
Thread begun 10/15/2009 1:07 pm by kiwinicknz383387 | Last modified 10/16/2009 9:46 am by Jason Byrnes | 1951 views | 1 replies |
kiwinicknz383387
Hello,
Could someone please advise me on this (i have attached a diagram as a reference)...
Our Clients first arrive at the Lochiel Print Home Site and upon entering their username & password (preferably supplied by us but not essential) they are then redirected to the appropriate client site where they can place orders.
The first time they arrive we would like to leave in place the ‘My Profile’ section so they can fill in there details. This means when they login through our home site on their next visit they are automatically logged in to their appropriate client site and they can go through the checkout procedure without having to manually fill out billing forms again etc.
It would be great to have just the one PowerStore database to cover all of these sites, is this possible?
Is this login behaviour setup possible with Security Assist?
If so without any coding knowledge? etc
Kind regards
Nick
The login portion can be done.
you would need to modify the users table and add two new columns. One for clients home page, this column will store the page name of the clients home page (clientSite1.php, clientSite2.php, etc...). The other to indicate if the profile has been updated, set this to a default value of 0. you will need to modify the update record server behavior on the profile page to set this value to 1 when the profile is updated.
Next, on the login page, double click the authenticate user server behavior. On the third page, you can select column from the users table to store in session variables. select the new ClientsHomePage and profileUpdated columns.
In the SecurityAssist Access Rules manager, you can create a new rule for profileUpdated.
Set it to allow if. Click the Lightning bolt next to value and select the ProfileUpdated session variable. Set the Criteria to Equal and set the comparison to 1.
Next apply the SecurityAssist page access behavior to the profile page, use the profileUpdated rule. Click the folder icon next to "if Access denied Go to". In the Select File Dialogue, click the Data Sources radio button and select the ClientsHomePage session variable.
applying this rule to the profile page will make it so the profile page can no longer be accessed if the profile has been updated, you'll probably want to make a copy of the profile page that does not have the access rule applied to it, and link to that profile page in your menu.
As for using the same power store database for each client store, you will only be able to do that if each store sells the exact same items.
