eCart calculation
Thread begun 10/15/2009 12:34 pm by Fritz Stickers | Last modified 11/24/2009 10:36 am by Eric Mittman | 5166 views | 7 replies |
Fritz Stickers
eCart calculation
The price for a product increase with 2,00 euro when the size increase with 5 cm.
The minimum price is 6,00 euro for 15 cm, so 20 cm=8,00; 25 cm=10,00; 30 cm=12,00.
WA_eCart calculation : [Price]+(((([Size]-15)/5)*2))
Now I want the price increase with just 1,00 euro from size 35 cm, so that 35 cm=13 euro.
How do I have to make the calculation ?
Regards,
Geert.
I was looking into this one for a moment and I think I have a calculation that will work for you.
The idea I was working with is that there is a max of 6 euro that will be added to the minimum price if the size is 30 or greater using your posted calculation. So I just made a calculation that checks if it is over 30cm and if so add 1 euro for each 5 cm over 30cm, then also add 6 euro to account for the maximum charge for the first calculation. If it is 30cm or less then just use the original calculation. Here is the calculation code:
[Price]+ (abs([Size] > 30) * ((([Size]-30)/5) + 6)) + (abs([Size] <= 30) * ((([Size]-15)/5)*2))
Please give this a try and let us know if it works for you. Sorry if my explanation of the code is confusing.
Fritz Stickers
Thanks Eric,
Calculation works fine !
Geert.
That is good to hear, I was hoping it would work for you. It took me a minute or two to review it and test it.
Fritz Stickers
I want to change the calculation a little bit :
I want also the price decrease 1 euro if size is 10 cm.
10 cm = 5,00 (-1,00)
15 cm = 6,00 (= 6,00)
20 cm = 8,00 (+2,00)
25 cm = 10,00 (+4,00)
30 cm = 12,00 (+6,00)
35 cm = 13,00 (+7,00)
40 cm = 14,00 (+8,00)
45 cm = 15,00 (+9,00)
I tried a lot of combinations for the calculation, but non of them works.
([Price]+ (abs([Size] = 10) * (([Size]-15)/5)) + (abs([Size] <= 30) * ((([Size]-15)/5)*2)) + (abs([Size] > 30) * ((([Size]-30)/5) + 6))))
Can you give it a try ?
Geert.
Fritz Stickers
I found it at last :
- 1 euro < 15 cm
+ 2,00 euro = 20,25 of 30 cm
+ 1,00 euro > 30 cm
([Price]+ (abs([Size] < 15) * (([Size]-15)/5))
+ (abs([Size] = 20) * ((([Size]-15)/5)*2))
+ (abs([Size] = 25) * ((([Size]-15)/5)*2))
+ (abs([Size] = 30) * ((([Size]-15)/5)*2))
Office Guy-172461
Thanks to both of you for sharing your formulas.
Calculation for price increase based on size
169/
Nice write up on this, I bet this will come in handy for others out there. Thanks.
