File uploads, but won't display on host server
Thread begun 10/15/2009 9:56 am by jstoler155201 | Last modified 10/16/2009 9:22 am by Jason Byrnes | 4215 views | 3 replies |
jstoler155201
First of all, this is in reference to the upload section of Power Store. But it applies to DFP.
I can upload and resize files to my test server and the host server, BUT, they only show up on the test server. When I go into the host server by ftp and check the Upload file, there are my images, but somehow they are set to a permission of only 600, they need to be 644 to display. I have the Images and Uploads folders at 755 and used 775, but the images always went to 600.
Is this DFP? My host claims it is not the server.
What can I do? And how do I update DFP, and the other extensions used in PowerStore? Several extensions, including DFP have issued new dot releases since I purchased PowerStore.
Thanks for your help.
To change the permissions after the files have been uploaded, you can use the chmod() php command.
On the products insert page, change:
WA_DFP_SetupUploadStatusStruct
("WA_UploadResult1");
if(
$_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1""ProductImage""2""[NewFileName]_[Increment]""true"$WA_UploadResult1_Params);
("WA_UploadResult2");
if(
WA_DFP_UploadFiles("WA_UploadResult2""ProductThumb""2""[NewFileName]_[Increment]""true"$WA_UploadResult2_Params);
To:
if(
chmod($WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]."".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"], 0644);
if(
chmod($WA_DFP_UploadStatus["WA_UploadResult2"]["serverDirectory"]."".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"], 0644);
unless you are experiencing specific bugs in power store, you should not need to update power store using the extensions.
There are some problems that we have identified in PowerStore that can be addressed using the files provided in the Known Issues section of the PowerStore download page.
jstoler155201
Thanks, that worked, what about updates?
Jason, thanks as always for the right answer. I also got the PowerStore know issues. Do I use the same code for updates, too?
Thanks,
Jay
You're welcome.
Yup, the update page will use the same edit.
