search crash...
Thread begun 10/15/2009 2:13 am by pejmanfallahi244687 | Last modified 10/16/2009 9:59 am by Eric Mittman | 1508 views | 1 replies |
pejmanfallahi244687
search crash...
I have 3 join table with many to many relation to another table, and keep the info of users. in search, I have 2 drop down which are depended (the first one is category and the second one is subcategory - " get the value from many to many table" -), also some users didnt set their sub category.(the sub category value store in many to many table)
Problem: when we choose only category,we get result, if we choose category and subcategory, the browser try to show the result but after some minutes, time out, and it crashing and show some incorrect result.
i think it happen, because, users didnt set the sub category and it loops in the database to find it and then crashes. can we personalize the search to show, if it has subcategory show if not remove from result page ?
the second problem, i want the search session be clean after some minute or if they left the page!(only search session).? because,if user search and come back again they see the result , not the whole record (we have also the reset)
please help with that.
PHP/mySQL
thank you
If your search is timing out it would indicate that the query is taking too long to execute. This is likely because of the complexity of the query and the responsiveness of the database.
In PHP you can extend the timeout period for a script with this code:
<?php set_time_limit(number of seconds); ?>
You just need to add in the number of seconds that you would like to allow the script to run.
As for the issue you are getting with incorrect results please explain this a little more. The time that it takes the query to execute should have no impact on the results that are returned.
