eCart 4.5.2 Activation
Thread begun 10/15/2009 12:19 am by bschochet234506 | Last modified 10/15/2009 11:46 am by Eric Mittman | 1470 views | 1 replies |
bschochet234506
I tried to install this new version and mistakenly did not deinstall version 4.5.1. I then tried to deinstall 4.5.1 and that did not work. At this point, I am not sure what extension is running but when I try to use whatever it is that I have I am now getting a javascript error on every function I try to use (Add eCart to site, Add to Cart, etc.). Your assistance would be greatly appreciated. Thank you.
You should delete your configuration folder so you can remove the currently installed extensions. Here is a link to a thread that gives instructions on clearing out this configuration folder so it can be recreated.
showpost.php?p=12293&postcount=2
Please give this a try, then after you have cleared the extensions from the extension manager you can install v4.5.2 as a fresh install.
