Generate the wrong recordset in DA !
Thread begun 10/14/2009 7:42 pm by kakadong | Last modified 10/16/2009 9:22 am by Jason Byrnes | 2432 views | 3 replies |
kakadong
I use the wizard to make a backend ....
when I finished, it generate 6 pages for me ..
results,details,insert,delete,update,search....
but some error in recordsets which DA generate....
the update, details , delete pages has the error...
the delete page code generate by DA :
$ParamAgent_ID_WADAagent_profile = "-1";
if (isset($_GET['Agent_ID'])) {
$ParamAgent_ID_WADAagent_profile = (get_magic_quotes_gpc()) ? $_GET['Agent_ID'] : addslashes($_GET['Agent_ID']);
mysql_select_db($database_connection, $connection);
$query_WADAagent_profile = sprintf("SELECT Agent_ID, Agent_Name, Agent_Identity, Agent_Birth, Telephone_Home, Telephone_mobile, E_Mail, County_ID, Town_ID, Zip_ID, Road, Bank_ID, Bank_Account, Level_ID, User_Name, Pass_Word FROM agent_profile WHERE Agent_ID = %s", GetSQLValueString($ParamAgent_ID_WADAagent_profile, "int"));
$WADAagent_profile = mysql_query($query_WADAagent_profile, $connection) or die(mysql_error());
$row_WADAagent_profile = mysql_fetch_assoc($WADAagent_profile);
$totalRows_WADAagent_profile = mysql_num_rows($WADAagent_profile);?>
the detail page :
$ParamSessionAgent_ID_WADAagent_profile = "-1";
if (isset($_SESSION['WADA_Insert_agent_profile'])) {
$ParamSessionAgent_ID_WADAagent_profile = (get_magic_quotes_gpc()) ? $_SESSION['WADA_Insert_agent_profile'] : addslashes($_SESSION['WADA_Insert_agent_profile']);
$ParamAgent_ID2_WADAagent_profile = "-1";
$ParamAgent_ID2_WADAagent_profile = (get_magic_quotes_gpc()) ? $_GET['Agent_ID'] : addslashes($_GET['Agent_ID']);
$query_WADAagent_profile = sprintf("SELECT Agent_ID, Agent_Name, Agent_Identity, Agent_Birth, Telephone_Home, Telephone_mobile, E_Mail, County_ID, Town_ID, Zip_ID, Road, Bank_ID, Bank_Account, Level_ID, User_Name, Pass_Word FROM agent_profile WHERE Agent_ID = %s OR ( -1= %s AND Agent_ID= %s)", GetSQLValueString($ParamAgent_ID_WADAagent_profile, "int"),GetSQLValueString($ParamAgent_ID2_WADAagent_profile, "int"),GetSQLValueString($ParamSessionAgent_ID_WADAagent_profile, "int"));
the update page :
when i double click the server behavior trying to make it correct
and click the test button..
the errors shows ....
can any body help me??
OS: win7 traditional chinese
DW cs4 english
This problem is caused by a the way Dreamweaver reads variables and using the Underscore Character in your column names.
When a variable is created in a recordset it is name "Param<ColumnName>". Dreamweaver writes the code for the parameter as "$Param<ColumnName>_<RecordsetName>.
upon re inspection, Dreamweaver sees everything after the first underscore character as the recordset name. so the column "Agent_ID" in the "WADAagent_profile" recordset will be named:
ParamAgent_ID
the code for the variable will be written as:
When you reinspect the recordset, Dreamweaver will read the parameter name as:
ParamAgent
and the recordset it is associated with as:
To keep the issue from occurring, you should avoid underscores in your column names.
To fix the problem, you will need to manually edit the code, and remove the underscores from the variabel names. change any instance of:
on the delete page to:
$ParamAgentID_WADAagent_profile
on the detail page, change these three:
$ParamSessionAgentID_WADAagent_profile
$ParamAgentID2_WADAagent_profile
On the update page, change:
kakadong
It seems fine!
after handcoding, it seems fine...
thanks for helping!
you're welcome.
