How to redirect browser if it is in IE 6?
Thread begun 10/14/2009 4:27 pm by arteydiseno381654 | Last modified 10/14/2009 5:51 pm by Eric Mittman | 2000 views | 3 replies |
arteydiseno381654
Hello!
I like to know how to redirect according to browser version.
For example:
If the user has IE 6 or earlier it redirects to error.php
Thank you!
Jimmy Wu
The code you would use to check if the page is IE6 or before is this:
<!--[if lte IE 6]>
<![endif]-->
In the if you'd want to put in the redirect code.
arteydiseno381654
but does not work:
<!--[if lte IE 6]>
if("" == ""){
$WA_Redirect_URL = "http://www.domain.com";
$WA_Redirect_KeepQS = false;
if ($WA_Redirect_URL != "") {
if ($WA_Redirect_KeepQS && $WA_Redirect_URL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "") {
$WA_Redirect_URL .= ((strpos($WA_Redirect_URL, '?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_Redirect_URL);
<![endif]-->
Since the conditional validation is client side the redirect should be also. Inside of the if you can put in a client side redirect like this:
window.location = "http://www.google.com/"
</script>
