Maps working for some folks, not for others
Thread begun 10/14/2009 3:35 pm by hearhear302530 | Last modified 10/15/2009 8:36 am by hearhear302530 | 3911 views | 5 replies |
hearhear302530
I just installed a new site after having tested it both locally and on my own site. I have two pages which contain Google maps generated by the WA Pro Maps extension. They have worked perfectly up to now.
I did get a new API key for the current installation, and I and some others can load the maps no problem. Others are getting a pop-up dialog stating that the credentials are for another site. This is odd, since I changed the key in the code. Even my friend in Spain can load the maps, but I've tried it on some of the machines at work and no go, except for my own desktop.
Can someone take a look-see and verify whether the maps are loading? If not, maybe someone could shed some light on what might be wrong.
rockville_map.htm
takoma_park_map.htm
Thanks!
I have tested both pages on several machines using FireFox, IE 7 IE8 and Safari. On all ofg the machines I have tested, the map loads with out a problem.
Jimmy Wu
The maps seem to be loading on the machines in our office. Is there some additional information that you can provide about the machines that the maps are not loading for?
Try clearing the cache on the browsers on the other machines to see if its a caching issue.
hearhear302530
The only common thread I can think of is that I work for a public school system and we have a mighty firewall in place. Thing is, it works on my desktop at work. I used that machine for viewing the site while testing it on my own domain, and it worked there as well.
Thanks for the input; I'll keep trying to track this down.
neilo
All good from here (FireFox, IE8, Safari)
hearhear302530
Thanks neilo!
