Undifined Variable: row_None
Thread begun 10/14/2009 2:30 pm by Lee Firth | Last modified 10/15/2009 10:05 am by Jason Byrnes | 1808 views | 3 replies |
Lee Firth
I seem to be having more than my share of problems at the moment. When I try to submit the attached page I get the following error:
PHP Notice: Undefined variable: row_None in C:\inetpub\wwwroot\firth_web_works\add_inv_create_items.php on line 339 PHP Notice: Undefined variable: row_None in C:\inetpub\wwwroot\firth_web_works\add_inv_create_items.php on line 339
Line 339 is part of the code added by applying the DataAssist Repeat Selection SB.
You have a multiple update server behavior on the page.
perform a multiple update, there must be a recordset present to return the ID of the records to update. There are no record sets on this page to be used, so $row_None was used instead. you cannot add the multiple update server behavior to a page that does not contain a recordset.
Lee Firth
My mistake, I should have used an insert SB not an update. Thanks for pointing that out.
No worries.
