How to use thumbnails instead of a form?
Thread begun 10/14/2009 11:22 am by maurizio.melandri390100 | Last modified 10/16/2009 10:48 am by maurizio.melandri390100 | 5523 views | 6 replies |
I would run a search on mysql using thumbnails of the categories. I produced pages search results and detail. I saw that the searh page passes 3 parameters to the results page, the first is the search key and ok, but the other two are Search.x and Search.y I do not know what values should hold and why.
When an image form element is used to submit a form, it does not pass a value, it will pass the x and y coordinates of where the mouse clicked on the image.
Search.x and Search.y just need to be set to a number:
Search.x=2&Search.y=3
will be fine
Well, I need to pass the search key on the database, like 'cpu' where 'cpu' is the value of the column being searched. I do not use a form, but thumbnails. After the click on the cpu image I prepare this string:
dhpc_prodotti_Results.php?cpu
with this istructions
<a href="../dhpc_prodotti_Results.php?<?php echo $_GET['S_dhpc_tipo']; ?>=sm"><img src="../images/simboli/mb.jpg" alt="Mother Board" class="interactiveThumbnails_img" title="Mother Board" /></a>
But dont functions when dhpc_prodotti_Results.php is displayed (but function test with dreamweaver
In this case I can not use DataAssist?
you need to include the Search.x and Search.y parameters in the link:
<a href="../dhpc_prodotti_Results.php?S_dhpc_tipo=sm&Search.x=2&Search.y=3"><img src="../images/simboli/mb.jpg" alt="Mother Board" class="interactiveThumbnails_img" title="Mother Board" /></a>
well, but with what values?
if you look at my example the values I use are 2 and 3. The actual values do not matter.
the Search.x and Search.y are the pixel x and y coordinates of where the mouse clicks the image button.
you can use any value for the Search.x and Search.y, the code is just checking that there is a value:
Search.x != ""
it is not checking for a particular value.
Search.x != ""
Ok, thank you, now is ok :)
