Submenus display BEHIND Flash slideshow
Thread begun 10/14/2009 7:41 am by lyn212943 | Last modified 10/14/2009 12:45 pm by Ray Borduin | 3840 views | 4 replies |
lyn212943
The left side vertical menu on this page index.html has submenus that display BEHIND the Flash slideshow even though I added a z-index of 999 to the Left Column.
Help is appreciated.
Lyn
Willi Schneider
Hi Lyn
Try to add this parameter to your flash animation:
<param name="wmode" value="transparent" />
So your code:
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="670" height="450" title="slideshow - battery families">
<param name="movie" value="/xml_demo.swf">
<param name="quality" value="high">
<param name="SCALE" value="exactfit">
<embed src="/xml_demo.swf" width="670" height="450" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" scale="exactfit"></embed>
</object>
Should look like that:
</object>
Sorry for the "grin"-smileys. That gets converted automatically by WA
you probably have to add it to your .js as well, so:
AC_FL_RunContent( 'codebase','http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0','width','670','height','450','title','slideshow - battery families','src','/xml_demo','quality','high','pluginspage','http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash','scale','exactfit','movie','/xml_demo' ); //end AC code
becomes:
AC_FL_RunContent( 'codebase','http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0','width','670','height','450','title','slideshow - battery families','src','/xml_demo','quality','high','pluginspage','http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash','scale','exactfit','movie','/xml_demo','wmode','transparent' ); //end AC code
lyn212943
Won't this just make the Flash object transparent?
Thanks, Ray
I'll try that. Won't this just make the Flash object transparent? Won't the Submenu still display behind the Flash image and the user still won't be able to click a submenu since it will be blocked (although visible) by the Flash element?
Thanks,
Lyn
No... although it sounds like it from the name it really just makes other things appear on top of it.
