iRite start up error message
Thread begun 10/14/2009 7:25 am by neal.umney286217 | Last modified 10/27/2009 10:06 am by Jimmy Wu | 3091 views | 4 replies |
neal.umney286217
Good day,
I have download and installed th latest versions of irite, and get the following error when I try and use it.
"While eecuting timer in WA_iRite.htm the following js error occured:!
line 176 iRiteShared.js .... rteSB.Nodes has no properties
Help. I have been through all the suggested 'while installing extensions problems, including backing up my config dir.
Any clues?
Office Guy-172461
Solving problems with Dreamweaver
146/
If deleting the cache file doesn't help:
Make sure you uninstall the extension before you install a new version. I would delete the cache file after installing the latest version. Backing up the config folder doesn't fix problems unless you also remove it so DW can rebuild it. This will mean you have to reinstall all of your extensions.
neal.umney286217
What I meant to say is.
I have done all those things, essentially starting from scratch. iRite is the only extension I have currently installed.
I followed the ipvac instructions very closely. When I said backed up the config dir I should have said re-named it, making Dreamweaver re-create it. Just in case I gor one of the steps in the ipvac ibnstructions wrong, I am doing the whole thing again including re-activating iRite.
The end result is exactly the same.
I have opened a ticket for you on this issue. Please login and visit your support history to update the ticket with the requested info.
Jimmy Wu
The user resolved this issue by reinstalling Dreamweaver and the extension.
