ProMaps for Google 1.0.5 generated map doesn't display in Opera 10.0
Thread begun 10/13/2009 2:08 pm by rtgDesign | Last modified 10/15/2009 2:53 pm by Eric Mittman | 4875 views | 5 replies |
rtgDesign
I used ProMaps for Google 1.0.5 to generate a map with PHP variables for the address. The map displays OK in the other browsers but just shows a gray box in Opera 10.0.
This was also tested on another machine using Opera 9.64 and failed.
Here is the link: myip.php
Thanks in advance.
The link you posted seems to not be working. I have created a test map with 1.0.5 and tested it in Opera 10. I get the map to display without issue. Do you have another link to the page where this can be seen? I will test you map out in my Opera to see what the result is.
rtgDesign
Hi Eric. Sorry, the link had a typo. I made the correction, try it again.
Thanks for the link. I was able to get the result you are reporting with just a grey block where the map should be in Opera 10. As a test of the map I have viewed the source and copied it to a static page of my own. When I view this page created from your source the map loads fine even in Opera 10. This indicates that the issue may be related to either something else you have on the page or something on your server. I think it is more likely something on the page that is conflicting with the map.
To further test this I added a base tag to the page and set it to your domain so that the resource links would point to yours. When I did this I tested the page again in Opera and the map displays ok, but when I view this page in FireFox it loads a grey box again.
This tells me that the problem is likely some conflict on the page, probably with some js code you have. As a test try creating a new blank page and apply the map on this page without any other styling or js code on it. Please post back and let us know how this works for you.
rtgDesign
I have created a new page as you suggested. I removed most of the code. The only code left is to pass 4 php variables.
The variables are: the user's actual IP address, Oakland, CA and United States.
The new link is: myip_test.php
It still fails for me in Opera.
I have opened a ticket for you on this so that we can exchange some files. To update the ticket please login and visit your support history.
