Urgent help needed please - Warning: date() [function.date]: in mail.php
Thread begun 10/13/2009 12:31 pm by rob75685 | Last modified 6/22/2010 7:04 am by Jason Byrnes | 4646 views | 4 replies |
rob75685
hi there
A contact page I've created using Universal Email tested fine on my server, but on posting the page live on another server it comes up with the following errors:
Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/London' for 'BST/1.0/DST' instead in /Library/WebServer/Documents/dev/WA_Universal_Email/mail_PHP.php on line 169
Warning: Cannot modify header information - headers already sent by (output started at /Library/WebServer/Documents/dev/WA_Universal_Email/mail_PHP.php:169) in /Library/WebServer/Documents/dev/customersatisfaction.php on line 48
Is it related to timestamp differences ?....
Thanks for your help
This means you are missing the default timezone setting in your php.ini.
You can either set it on the top of the page:
function.date-default-timezone-set.php
or add it to your php.ini:
viewarticle.php?aid=100&pid=3&uid=1
rob75685
Thanks very much for the quick response Ray
sindhu_happy85409697
Date function
Give me suggestions
can you provide more details on what you would like suggestions to do?
If you need more information on the php date function, see the php.net date manula page here:
function.date.php
