Limited prices for shipping
Thread begun 10/13/2009 9:14 am by mrs | Last modified 10/13/2009 9:29 am by Ray Borduin | 1411 views | 1 replies |
mrs
Hi, I want to be able to have a single price for shipping across the board for medium and large products, say £7.50.
At a later stage I will also be shipping small items which will then be given a different price for shipping of £3.50.
How would I achieve this limited range of shipping prices?
Thanks.
Are you going to consider quantity as well? Is that per item, per quantity, or a total for the whole order?
You would just create a shippiing rule defining the charges that you want. If you differentiate based on item size, then you would have to include that size as part of the cart... maybe use the weight field since you probably aren't using it for anything else. Then determine a cut-off weight for medium and large products and charge shipping based on the total or individual column weights depending on how you answer my questions above.
