Andrew
Thread begun 10/13/2009 6:28 am by andykeltic379625 | Last modified 10/14/2009 7:25 am by Ray Borduin | 3368 views | 5 replies |
andykeltic379625
Andrew
Powerstore is not sending order confirmation e-mail to customer.
I have changed the following in confirm.php
// WA eCart Store Cart Details in Db
if (isset($_POST["Submit_order"])) // Trigger
$WA_connection = $localhost;
$WA_table = "orderdetails";
$WA_redirectURL = "checkout_success.php";
to
$WA_redirectURL = "";
they now recieve e-mail but powerstore doesent go to checkout_success.php now
any help please
Andy
Are you using a payment gateway? Probably the solution is to add the success page as the redirect in the email code.
andykeltic379625
Andrew
Not using any gateway just confirmation e-mail needed, no credit card payments taken on line. My customer gets in touch with clients after order sent
Ok, well then that is the solution... Usually the success page is specified as part of the payment processing.
If you have universal email, just update the redirect in that server behavior. Otherwise you will have to update the code where the email is sent to add the redirect page manually...
You would update it from:
if (""!="") {
header("Location: ");
if ("checkout_success.php"!="") {
header("Location: checkout_success.php");
andykeltic379625
Andrew
Do you mean change this in the checkout_success.php
// WA eCart Redirect
if ($WA_Store_Cart->redirStr != "") {
header("Location: ".$WA_Store_Cart->redirStr);
to
Andy
Nope. I mean update it where universal email is applied.
Start by finding the comment:
//WA Universal Email object
the redirect I refer to will be a couple of lines below that.
