Form submits but mail does not arrive
Thread begun 10/12/2009 11:18 pm by rmruda390861 | Last modified 10/15/2009 5:27 pm by Jimmy Wu | 5297 views | 8 replies |
rmruda390861
Just started using your software and have followed all relevant tutorials ( I hope). Simply trying to email a test form using UE after building form with FB.
Email is not arriving. I have tried a few variations in the mail object properties (SMTP). I know this ISP accepts PHP mail() as I have used before so I have tried to leave SMTP blank but also mail.ourdomain.com. Neither has worked. I have also tried different "triggers" - the actual submit and "any form post" I see that when click on the lightning icon there are two groups of fields to expand (1 for what looks like client side and the other server side validated entries). I have tried both submit fields..
Once I hit the submit button the contactthanks.php file is loaded ok but no email arrives.
As per Ray Borduins posting 04-14-09 "Advice on how to setup Universal Email settings " I added to mail_PHP.php:
var_dump($mailObj);
die();
after
$mailObj = mail($mailTo,$mailSubject,$mailContent,$mailHeader );
Browser returned "bool(false)" which I guess means email was NOT successfully sent to my SMTP server.
Please see attached files zipped.
The problem seems to be on the page where universal email is applied.
The code:
$RecipientEmail = false;include("WA_Universal_Email/WAUE_online_request_wa_1.php");
should be something like:
$RecipientEmail = 'youremail@yourdomain.com';include("WA_Universal_Email/WAUE_online_request_wa_1.php");
The code:
rmruda390861
Ray,
THANK you for the fast response.
Yes that definitely looks like a problem. I did change it to one of my emails but I am still getting:
"bool(false)"
Now the domain I am "$RecipientEmail" is a gmail account. I presume the UE will allow this and does require the true website domain. I am not sure why UE came up with that "false" instead of that gmaill I entered in the "TO:" tab of UE ??
Not sure what to do next now.
Richard
I'd be concerned that other values may not have been set properly. I'll open a support incident so that we can investigate this problem with you directly.
Update your support history on our web site to include a phone number and will give you a call to investigate potential issues.
rmruda390861
Ray,
OK thank you. Phone # added.
R
Jimmy Wu
We were able to determine the issue as the from email was being set to the wrong variable. After setting the from variable to the correct value, the email was sent correctly. The from email should be set to the form data binding that the user enters their email address for the purpose of this particular form. It was being set to the validated entries binding instead.
rmruda390861
Thank you very much Jimmy.
Richard
Jimmy Wu
Glad we were able to assist you to get your issue resolved quickly.
247logistics138023
I am having same problem
This post has been deleted.
