Menu system Mistake
Thread begun 10/12/2009 7:33 pm by GaryDCoxDFW | Last modified 10/13/2009 1:37 pm by GaryDCoxDFW | 3485 views | 3 replies |
GaryDCoxDFW
Menu system Mistake
I made some mistake on the menu system on this test site on the video menu, if you you try to go between video1 to video2 you get an error, Here is the test site:
index.html
I did a manual edit first getting the home menu correct, but when I made the changes to the template this occured, can you give me a hint to my mistake.
Also i need to generate a catagory 4 in the gallery menu how do I do that?
neilo
Video 1 Link goes to:
http://test.html.ultrawatercreations.com/videoclips/customer1/video1a.html
Video 2 Link goes to:
http://test.html.ultrawatercreations.com/videoclips/customer1/videoclips/customer1/video1b.html
i.e. in the URL for video 2, there is a duplicate 'videoclips/customer1/' in the path.
Check the paths.
Jimmy Wu
As Neilo said the path is what is causing the issue.
In addition if you have Menu Writer, you can edit the menu using that to prevent hand coding errors.
GaryDCoxDFW
Answer to question
I have all your products, so I will look at it, thanks
