Street view?
Thread begun 10/12/2009 3:56 pm by ian42475 | Last modified 11/05/2009 2:27 pm by Jason Byrnes | 11443 views | 12 replies |
ian42475
Street view?
Hi
Is there anyway to get the map to show the street view onload? or is that part of API 3 and therefore no part of the extension at the moment or am i overlooking something?
Desperate to get this functionality into my application
Ian
Street view is not a feature that is available in Pro maps, though you can modify the promaps .js file to include it.
First you need to add a div to display the street view panorama:
html:
<div id="pano" style="width: 300px; height: 300px;"></div>
next you need to modify the maps .js file to add street view.
in the .js file, find the following line:
var map = new GMap2(document.getElementById('wagmp_map_1'));
the number "wagmp_map_1" may be differant.
and add the following after it:
var myPano = new GStreetviewPanorama(document.getElementById("pano"));
Then find each occurance of:
map.addOverlay(marker_0);
the number in "marker_0" my be different and will change depending on how many addresses are in your map.
svOverlay = new GStreetviewOverlay();
map.addOverlay(svOverlay);
myPano.setLocationAndPOV(point);
GEvent.addListener(map,"click", function(overlay,latlng) {
myPano.setLocationAndPOV(latlng);
ian42475
awesome thanks
awesome thanks
ian42475
Using lat and long
Hi
I have this working great on one site using the address to position streetview (addressType: 'address',) but a new one i'm implementing is using lat and long not address (addressType: 'coordinates',), is it possible to use lat and long with street view?
at the moment <div id="pano" style="width: 300px; height: 300px;"></div> is not showing
Many thanks for any advice
Regards
Ian
Yes, you should be able to use street view with latitude and longitude.
Can you post a link so I can take a look.
ian42475
street view
Thanks Jason
Test area is here: map.php?property_id=14472
Problem seems to be that 'mypano' is NULL or not an object
I set the webassist extension to look up the lat and long fields from the db and then applied the above amends as i did for the address version
Ian
you are missing the code that defines the myPano variable:
add that code just after:
ian42475
thanks
Doh!
Thanks, will pay more attention next time
One other question, is it possible to point the street view at a building rather than up or down the road?
Ian
the myPano.setLocationAndPOV() function can take 2 arguments, 1- lat long for the address, 2- options
there are 3 option: 1- yaw. 2- pitch, 3- zoom
you can control where the camera is facing using the yaw.
From googles api documetation:
  Street View Points of View (POV)
The Street View location defines the placement of the camera locus for an image, but it does not define the orientation of the camera for that image. For that purpose, the GPov object literal defines three properties:
* yaw defines the rotation angle around the camera locus in degrees relative from true north. Yaw angles are measured clockwise (90 degrees is true east).
* pitch defines the angle variance "up" or "down" from the camera's initial default pitch, which is often (but not always) flat horizontal. (For example, an image taken on a hill will likely exhibit a default pitch that is not horizontal.) Pitch angles are measured with negative values looking up (to -90 degrees straight up and orthogonal to the default pitch) and positive values looking down (to +90 degrees straight down and orthogonal to the default pitch).
* zoom defines the zoom level of this view (effectively proscribing the "field of view") with 0 being fully zoomed-out. Different Street View locations may provide higher or lower zoom levels.
By default, these values are all 0 and define a flat horizontal view directly north with the widest possible field of view.
change:
myPOV = {yaw:90};
myPano.setLocationAndPOV(point, myPOV);
to change the POV to face East instead of north.
ian42475
awesome
Amazing Jason
Thanks so much i have an excellent solution now
I am assuming that what you mean by there are only 2 arguments available is that lat/long or address is first arguement then i can either pitch zoom or yaw for that position and not use yaw with zoom also?
Many thanks, your help has been truly awesome
Ian
