Error message on confirm page when integrating Sagepay
Thread begun 10/12/2009 6:32 am by blu | Last modified 10/16/2009 4:56 pm by Jason Byrnes | 5939 views | 5 replies |
blu
Hi there
I'm trying to link ecart to SagePay. I'm using version 4.5.2.
I've gone through the checkout wizard (using a made-up merchant number as I'm testing while awaiting the real number from my client since he's in a hurry) and when I test it afterwards I'm getting the following error message on a blank screen after I enter contact details into the checkout page and click over t the confirm.php page:
Unknown column 'lrp7c4pbdf6qtgnj6drofecia3' in 'field list'
Searching all site files for 'lrp7c4pbdf6qtgnj6drofecia3' turns up no results.
Please help. I'm stuck and can't find anything similar in the other forum threads.
Bruce
Dani Chankhour
Whenever you receive "Unknown Column ..." type of errors, indicates that you are trying to store the wrong type in your table column. Most likely, you could be trying to store the session id in a table column with an integer type.
I would recommend looking over you table and make sure that you have the correct data type for each column and also make sure you are storing the correct information for that column.
blu
OK, not sure how that happened as I just followed the wizard and ecart generated the tables. Perhaps I just selected the wrong field when going through the wizard (the help system isn't as helpful as it could be as it seems to be only for ASP users and I'm PHP).
Anyway, code below for the confirm.php page if anyone can have a look to see if there's any obvious mis-assignment. I've set up both order summary and order details storing as you can probably see.
Wish I could just enter the wizard again and show how I've assigned them in windows, but it seems like a one-time deal and I can't find a way to bring those windows up again (please let me know if there's a way to do this - I can't find anything in the help system).
Code:
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
<?php require_once('Connections/hab.php'); ?>
$eCart1->GetContent();
//WA eCart Include
require_once("WA_eCart/WA_eCart_Database_PHP.php");
if($_SERVER["REQUEST_METHOD"] == "POST") {
$_SESSION["eCartCheckoutForm_state_province"] = "".((isset($_POST["state_province"]))?$_POST["state_province"]:"") ."";
$_SESSION["eCartCheckoutForm_country"] = "".((isset($_POST["country"]))?$_POST["country"]:"") ."";
$_SESSION["eCartCheckoutForm_shipping_state_province"] = "".((isset($_POST["shipping_state_province"]))?$_POST["shipping_state_province"]:"") ."";
$_SESSION["eCartCheckoutForm_shipping_country"] = "".((isset($_POST["shipping_country"]))?$_POST["shipping_country"]:"") ."";
// WA eCart Store Cart Summary in Db
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $hab;
$WA_table = "shop_order_summary";
$WA_redirectURL = "";
$WA_indexField = "orderuserid";
$WA_fieldNamesStr = "ofderreferenceid|ordershipping|ordertax|ordersubtotal|ordertotal|orderstatus|billingname|billingaddress|billingphone|billingemail|shippingname|shippingaddress|shippingphone|shippingemail";
$WA_fieldValuesStr = WA_eCDB_ConvertNumber("".session_id() ."") . "|" . "".$eCart1->GetShipping() ."" . "|" . "".$eCart1->GetTax() ."" . "|" . "".$eCart1->GetTaxableTotal() ."" . "|" . "".$eCart1->GrandTotal() ."" . "|" . "placed" . "|" . "".((isset($_POST["lastname"]))?$_POST["lastname"]:"") ."" . "|" . "".((isset($_POST["street1"]))?$_POST["street1"]:"") ."" . "|" . "".((isset($_POST["phone"]))?$_POST["phone"]:"") ."" . "|" . "".((isset($_POST["email"]))?$_POST["email"]:"") ."" . "|" . "".((isset($_POST["shipping_lastname"]))?$_POST["shipping_lastname"]:"") ."" . "|" . "".((isset($_POST["shipping_street1"]))?$_POST["shipping_street1"]:"") ."" . "|" . "".((isset($_POST["shipping_phone"]))?$_POST["shipping_phone"]:"") ."" . "|" . "".((isset($_POST["shipping_email"]))?$_POST["shipping_email"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_sessionName = "eCart1_OrderID";
$WA_Sql = "";
$NeedInsert = false;
$indexFieldIndex = -1;
$WA_connectionDB = $database_hab;
$updateFieldValue = "";
if ($WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos('?', $WA_redirectURL) === false)?"?":"&").$_SERVER["QUERY_STRING"];
for ($i = 0; $i < sizeof($WA_fieldNames); $i++)
if ($WA_indexField == $WA_fieldNames[$i])
$indexFieldIndex = $i;
break;
$deleteFieldValue = "";
$updateColType = "none,none,NULL";
if ($indexFieldIndex >= 0) $updateFieldValue = $WA_fieldValues[$indexFieldIndex];
if ($updateFieldValue == "" && isset($_SESSION[$WA_sessionName])) $updateFieldValue = $_SESSION[$WA_sessionName];
if ($indexFieldIndex >= 0) $updateColType = $WA_columns[$indexFieldIndex];
if ($updateFieldValue != "") {
$updateParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, $indexFieldIndex);
$valueForWhere = WA_generateInsertParams(array($WA_indexField), array($updateColType), array($updateFieldValue), -1);
$WA_Sql = "update " . $WA_table . " SET " . $updateParamsObj->WA_setValues . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues;
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = $updateFieldValue;
$result = mysql_query("SELECT * FROM " . $WA_table . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues, $WA_connection);
$num_rows = mysql_num_rows($result);
$NeedInsert = (mysql_num_rows($result) === 0);
if ($updateFieldValue === "" || $NeedInsert) {
$insertParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "insert into " . $WA_table . " (" . $insertParamsObj->WA_tableValues . ") values (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
header("Location: ".$WA_redirectURL); exit;
// WA eCart Store Cart Details in Db
$WA_table = "shop_order_details";
$WA_indexField = "orderdetailsid";
$WA_fieldNamesStr = "orderdetailsid|productid|productname|productdescription|quantity|price";
$WA_fieldValuesStr = WA_eCDB_ConvertNumber("".((isset($_SESSION["eCart1_OrderID"]))?$_SESSION["eCart1_OrderID"]:"") ."") . "|" . WA_eCDB_ConvertNumber("".$eCart1->DisplayInfo("ID") ."") . "|" . "".$eCart1->DisplayInfo("Name") ."" . "|" . "".$eCart1->DisplayInfo("Description") ."" . "|" . WA_eCDB_ConvertNumber("".$eCart1->DisplayInfo("Quantity") ."") . "|" . "".$eCart1->DisplayInfo("Price") ."";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL|',none,''|',none,''|none,none,NULL|',none,''";
$WA_sql = "";
mysql_select_db($database_hab, $WA_connection);
break;
$deleteFieldValue = $WA_fieldValues[$indexFieldIndex];
if (isset($deleteFieldValue) && $deleteFieldValue != "")
$deleteParamsObj = WA_generateInsertParams(array($WA_indexField), array($WA_columns[$indexFieldIndex]), array($deleteFieldValue), -1);
$WA_sql = "Delete from " . $WA_table . " where " . $WA_indexField . " = " . $deleteParamsObj->WA_dbValues;
$WA_editCmd = mysql_query($WA_sql, $WA_connection) or die(mysql_error());
$WA_okToDelete = false;
$eCart1->MoveFirst();
while (!$eCart1->EOF())
$WA_sql = "insert into ".$WA_table." (".$insertParamsObj->WA_tableValues.") values (".$insertParamsObj->WA_dbValues.")";
$eCart1->MoveNext();
if ($eCart1->IsEmpty()) {
$eCart1->redirStr = "ecart.php";
$eCart1->cartAction = "RedirectIfEmpty";
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
?><?php
require_once("WA_eCart/checkoutScripts/Protx_VSPForm.php");
thanks in advance
Bruce
blu
Oh, my bad. I think I created the tables manually rather than ecart creating them. SQL of the both of them below:
CREATE TABLE `shop_order_summary` (
`orderid` int(11) NOT NULL auto_increment,
`ofderreferenceid` int(11) default NULL,
`orderuserid` int(11) default NULL,
`ordershipping` varchar(24) default NULL,
`ordertax` varchar(24) default NULL,
`ordersubtotal` varchar(24) default NULL,
`ordertotal` varchar(24) default NULL,
`orderdate` date default NULL,
`orderstatus` varchar(80) default NULL,
`billingname` varchar(250) default NULL,
`billingaddress` varchar(250) default NULL,
`billingphone` varchar(40) default NULL,
`billingemail` varchar(250) default NULL,
`shippingname` varchar(250) default NULL,
`shippingaddress` varchar(250) default NULL,
`shippingphone` varchar(40) default NULL,
`shippingemail` varchar(250) default NULL,
PRIMARY KEY (`orderid`)
CREATE TABLE `shop_order_details` (
`orderdetailsid` int(12) NOT NULL auto_increment,
`orderid` int(12) NOT NULL default '0',
`productid` int(12) NOT NULL default '0',
`productname` varchar(250) NOT NULL default '',
`productdescription` varchar(250) default NULL,
`quantity` int(4) NOT NULL default '0',
`price` varchar(24) NOT NULL default '0.00',
PRIMARY KEY (`orderdetailsid`)
I'm running some tests to see if changing some of the field types fixes my problem
Bruce
blu
OK, I've tried changing 'ofderreferenceid' into a varchar (80) to see if that helps as that's the field that holds the session id but I'm getting the same error
(I've corrected a typo and changed the name to 'orderreferenceid' as well updating both the confirm.php file and the database table - just for information)
Anyone got any ideas?
The store cart summary server behavior is setting the data type for the orderreferanceid column to a numeric data type.
double click the store cart summary server behavior, select the orderreferanceid column and set the data type to text.
