Session not ending
Thread begun 10/12/2009 5:34 am by 4egidio363291 | Last modified 10/23/2009 12:03 pm by Eric Mittman | 8900 views | 18 replies |
4egidio363291
Session not ending
When a user chooses to purchase another product, paypal says that the product has already been purchased. It also sometimes saves over the previous product purchased in the database. I don't think the session is ending.
I attached the necessary pages.
Office Guy-172461
Maybe this will help
Cleaning all sessions after checkout
154/
4egidio363291
not working
thanks for the tip, but I couldn't get it to work
anyone else?
tom92909Beta Tester
Add the following to the bottom of your checkout success page...
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (isset($_COOKIE[session_name()])) {
setcookie(session_name(), ''time()-42000'/');
// Finally, destroy the session.
session_destroy();
</body>
4egidio363291
session
I already have that at the bottom of my checkout_success page.
Have you tried adding the code in for regenerating the id like this:
session_regenerate_id();
This may help if the problem is a persistent session id. However the code and troubleshooting tips that have been posted already should also be clearing out the session for you.
To test to see if your session is being cleared out properly just after the session destroy code that you have put in this code:
var_dump($_SESSION);
This line of code should print out the contents of the session object and let you know exactly what is in the session at the end of this checkout success page.
4egidio363291
session
Where do I add this code?
PHP Code:
PHP Code:
I already have that line:
@session_start();
echo("Before destrying the session: ");
echo("<br />");
@setcookie(session_name(), '', time()-42000, '/');
session_destroy();
echo("After destrying the session: ");
I don't get to see the success page because it stops at the paypal page saying that the order has already been placed.
I think the last part you said may be the key to this:
Since this code should be running on the success page if you do not get to it the sessions will not be cleared. You would not want to clear out the sessions before you get to this page, only after you get to this page.
You should try closing your browser and run another test knowing if you do not get to the success page the session variables will not be reset. Once you go through a transaction and get to the success page the variables will be reset and you will be able to test it again.
4egidio363291
Session
I tried running a test purchase and keep getting the same error.
This invoice has already been paid. For more information, please contact the merchant.
Prior to this, I was able to make a purchase but then when I want to make another one I get stuck on the above error.
Please advise,
So that we are clear on what is happening are you saying that you cannot get a successful transaction regardless of how you test it? If you are getting this error when you try to transact there must be something to it.
To help determine what may be going wrong you should print out the values that you are passing to PayPal on this page you are getting to. You will need to have these values on the page and run a test, then close out the browser or use another one to run another test. On your next test you should compare what you have on this page with what you had during the first test. This will help to clear up what values are being passed to PayPal that may be a problem. If the problem is an invoice number then you should be looking at this value very closely.
