Error after pressing submit
Thread begun 10/10/2009 7:22 pm by ideasbyjr63389 | Last modified 10/13/2009 8:36 am by Ray Borduin | 2079 views | 2 replies |
ideasbyjr63389
Error display on page after pressing Submit using a form with Digital Pro2.02
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 1"
Any ideas?
anonymous
Yeah... I have a lot of ideas, but can't narrow it down unless you can ost the code here. :D
That error typically is a result of a one missing closing parenthesis, bracket, quote, etc.
It could be one of several small things. Post the code if you can and let us have a look at it.
Best regards,
Brian
It is almost certainly a missing ')' as the error implies, but without seeing the code at the line where the error occurs, it is impossible to tell you where to add it as Brian suggests.
