Updateable Cart Buttons Dont Do Anything
Thread begun 10/10/2009 1:52 am by sfranzken73972 | Last modified 10/13/2009 9:19 am by Ray Borduin | 1490 views | 1 replies |
sfranzken73972
I have an updateable cart page but the buttons like checkout which should go to checkout.asp and clear cart which should go to productslisting.asp do not do anything but stay on the same attached page viewbag.asp (see attached)
Also, when I put a redirect if cart empty behavior nothing happens when you clear the cart
it just stays on viewbag.asp and reads "your cart is empty" rather then redirect as it should to productslisting.asp
Please help
Steve
Move this code that is on top of the page:
' WA eCart Redirect
if (eCart1_redirStr <> "") then
Response.Redirect(eCart1_redirStr)
end if
to just above the <html> tag after the rest of the server side code.
That should fix the redirect issues.
