Should we remove the old versions of eCart?
Thread begun 10/09/2009 8:59 am by carlene | Last modified 10/09/2009 5:19 pm by Jason Byrnes | 2911 views | 3 replies |
carleneBeta Tester
Hello! Should I remove the previous version of ecart server behavior from my store pages and start over on these pages with the new version if I'm using repeat region and PHP and they weren't working before? In other words the fixes specifically address the problems I was having. I was wondering if just installing the new version was enough - or if it was necessary to re-apply the new version's server behavior to my pages that had the previous version.
Thanks!
You will need to reapply the new version for the code on the page to be updated.
carleneBeta Tester
Jason,
Thanks for your help. Would you then suggest that I first remove the server behavior, then re-apply it. Or can I just re-apply it to each page? And should I rebuild my shopping cart page and checkout pages as well?
Thanks!
First remove the server behavior from the page, then reapply it.
if the checkout pages work, there is no need to recreate them.
